engine stays running after key off - Chevelle Tech
post #1 of 10 (permalink) Old May 3rd, 09, 10:01 AM Thread Starter
What causes an engine to stay running for a few seconds after the key is shut off. No it is not desieling it is running like normal for up to 8-10 seconds then turns off. This is a new 350 that was put into a cutlass. Any ideas?
Unleash the fury Mitch, UNLEASH THE FURY!!!
deck6972 is offline
post #2 of 10 (permalink) Old May 3rd, 09, 11:28 AM
Rich
Re: engine stays running after key off
Most likely your alternator is backfeeding through the system. Try disconnecting the small connector on the alternator, and then start and shut off the car. If you changed any circuitry, or added anything that is probably what is allowing it. I have seen this on AMCs.
Buh Waaaa is offline
post #3 of 10 (permalink) Old May 3rd, 09, 11:54 AM
I did this years ago in a camaro. I wired the electric cooling fans to a power source in the fuse panel, turned out to be another accessory terminal for the ignition. The engine would stay running untill the fans stopped turning.
Somewhere the power is backfeeding to your ignition, I'm guessing HEI dist.?
1966 SS Chevelle LQ4-4L80E
1965 SS Malibu Race car
1970 C-10 SWB Tow pig
www.u11racing.com
66SSFan is offline
post #4 of 10 (permalink) Old May 3rd, 09, 12:42 PM
bln
also make sure your ground wire is on from the block to the firewall
bln is offline
post #5 of 10 (permalink) Old May 3rd, 09, 2:14 PM
Josh
If you are running an MSD box, you need to install the Diode they included. I think it goes inline between the box and the coil. The capacitance of the box may continue feeding the coil after the power is cut. The diode allows voltage in only one direction so it will block any backfeed after you shut down.
If you're not running an MSD box, then.... I dunno .
Electronics scare me.
My 72 Pro Touring Project
496 BBC-617 HP @ 6100
587 ft/lbs. @ 5100
Tremec TKO 600
Strange S60 W/ 4.10's
Heidt's A Arms--CPP Big Brake Kit
Heidt's Drop Spindles--Qa1 Front Coilovers
http://i277.photobucket.com/albums/k...u/IMG_3723.jpg
BigRat09 is offline
post #6 of 10 (permalink) Old May 3rd, 09, 6:18 PM
Banned
Timing might be off
shonuff is offline
post #7 of 10 (permalink) Old May 3rd, 09, 6:41 PM Thread Starter
OK lets start with ground cable is attatched to block and firewall. Same alternator was used just changed motors, olds to chevy. No msd. Fans are wired to turn on and off with ign. Changed dist from olds to chevy.
I will try all suggestions just to cover my bases. Any other ideas we will try till it is fixed. Thanks
deck6972 is offline
post #8 of 10 (permalink) Old May 3rd, 09, 7:10 PM
Appears your running electric fans, are wired though relays? If not they should.
If they simply wired into the ignition circuit the electric fans act like a generator once the power field is removed and they will generate power as long they are spinning fast enough which will feed back though the circuit and provide enough power for the dist/ignition the allow the engine to run until the fans stop. properly wired relays not only allow to pull power from a high circuit such as directly from the battery, but isolate will ignition circuit from the feedback.
cachevelle66
65 El Camino
66 Chevelle SS
67 Chevelle www.fquick.com/cachevelle67
Finished 5-25-2007
69 Chevelle
67 SS/RS 396 Camaro Conv.
cachevelle66 is offline
post #9 of 10 (permalink) Old May 3rd, 09, 8:49 PM
Ryan
Originally Posted by shonuff View Post
Timing might be off
I agree, adjust your distributor and turn the car on and off see what happens.
rock72chevelle is offline
post #10 of 10 (permalink) Old May 3rd, 09, 9:18 PM
Josh
Ya. What he said. Every fan mnf. suggests a relay... notsure why until now. Makes absolute sense though.
587 ft/lbs. @ 5100
Tremec TKO 600
BigRat09 is offline
