1966 10 bolt to 12 bolt - Chevelle Tech
post #1 of 18 (permalink) Old Apr 15th, 08, 12:06 PM Thread Starter
I am new here.. I own a 1966 Chevelle.
I blew my 10 bolt on the way to Hot August Nights in Reno last August. I am finally getting around to dealing with it. I have made the decision to upgrade to a 12 bolt, and to buy a new aftermarket one (my car is not matching numbers or all original). I am leaning toward the Moser brand...
Any opinions and or comments are welcomed about the above info, however the information I am most interested in is what differences am I going to run into from the 10 bolt to the 12 bolt??
Drive shaft length? Brackets and Hardware Differences? Brake lines? etc.?
Thanks in advance for any information.
since everyone likes pictures:
red66chevelle is offline
post #2 of 18 (permalink) Old Apr 15th, 08, 12:11 PM Thread Starter
Re: 1966 10 bolt to 12 bolt
I guess this should have gone in the 'Mechanical' -'Transmission & Driveline' section... my bad. My apologies to the admins.
post #3 of 18 (permalink) Old Apr 15th, 08, 12:25 PM
Tom Lloyd
Pretty easy swap.
The universal joint is a different size. I think that covers it.
EDIT: nice car, and welcome!
Tom Lloyd
my 66
take my advice, I'm not using it.
floyd66 is offline
post #4 of 18 (permalink) Old Apr 15th, 08, 12:47 PM Thread Starter
Thanks Floyd. I'll make sure to get the U-Joint sorted before I begin.
post #5 of 18 (permalink) Old Apr 15th, 08, 1:18 PM
Nice chevelle Chris, What color is that? Should be an easy swap as Tom stated. Good luck.
Jamie Clayton
67ss
jc67 is offline
post #6 of 18 (permalink) Old Apr 15th, 08, 1:29 PM
Lenny
I did the same swap and the only difference is the u-joint and an easy swap on my 67
67 Chevelle with 509
69 Chevelle with 468 roller motor
87 Grand National
Len67Chevelle is offline
post #7 of 18 (permalink) Old Apr 15th, 08, 3:59 PM
Robert
Welcome...
'67 Elky Global West suspension kit with coil over QA1's, 435hp Edy Crate,700R4, Currie +9 3:75, Disc brakes front and rear, Dakota Digital gauge package, 12 Circuit Painless wiring kit, Ididit tilt Colum, etc.
2012 HD Tri-Glide in Vivid Black.
1967 XR7 Cougar S code 390.
2016 Charger R/T in Purple.
rak1 is offline
post #8 of 18 (permalink) Old Apr 15th, 08, 6:57 PM Thread Starter
Thanks to all for the compliments.
jc67, The color is 'Viper Red'.
post #9 of 18 (permalink) Old Apr 15th, 08, 11:54 PM
That is the color of mine as well I cant wait until I get mine put back together
Jamie Clayton
67ss
jc67 is offline
post #10 of 18 (permalink) Old Apr 16th, 08, 12:03 AM
I just did the swap a couple of weeks ago. If you are so inclined, this is a great time to add boxed control arms, and replace the bushings in your control arms. You'll be surprised how bagged out the stock ones look if they are original. I went with new poly bushings, as they came with my package deal.
And as previously stated, that is a very nice ride you have there.
OutCast is offline
post #11 of 18 (permalink) Old Apr 16th, 08, 1:55 AM
Matt
I'm actually interested in doing the same swap. Thanks for the question and the replies. Now I at least know what I'm in for.
oh and I'll echo what other have said.. Nice 66!!
Havok1327 is offline
post #12 of 18 (permalink) Old Apr 16th, 08, 8:37 AM
65 Malibu SS
If the Moser 12 bolt is like the stock 12 bolt you'll need to change the rear upper control arms. The 10 bolt upper arms won't work.
See this link for info: http://www.leverfamilysite.com/Rear_...ifferences.htm
JYags is offline
post #13 of 18 (permalink) Old Apr 16th, 08, 11:51 AM Thread Starter
Interesting...
JYags, thanks for the heads up and the link. I wonder why others did not have any issues with the swaps?
post #14 of 18 (permalink) Old Apr 16th, 08, 12:20 PM
65 Malibu SS
You could call Moser and talk to one of their techs about the swap.
JYags is offline
post #15 of 18 (permalink) Old Apr 16th, 08, 12:58 PM Thread Starter
I was planning on calling Moser very soon. I was trying to gather as much info as possible prior to making the call to Moser...
I spoke with Glenn Lever from the link you posted about the upper arm. He was extremely helpful and answered a lot of questions I had. He explained that the Drivers side is the only side that interferes, and that some people just use the 10-bolt one and it will rub away till it clears.
This Thread is more than 3295 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
