1970 Chevelle LS6 quarter mile time - Chevelle Tech
post #1 of 8 (permalink) Old Apr 14th, 08, 10:17 PM Thread Starter
As I recall when tested as a new car, the 1970 Chevelle LS6 ran a 13 something, I can't remember if it was a 13.4 or a 13.8.
My question is this....when they tested the car at the strip in 1970, did they run slicks on the rear? Or bias plys?
I ask because I always thought they ran the car bone stock out of the box, right down to the factory bias ply tires. But I have another guy trying to tell me they ran slicks on the rear and that the car ran 13's with slicks and 14's with the bias ply tires.
Anyone know for sure which was ran to get the 13 second time reported in 1970?
Thanks.
'71 Malibu 402 big block/TH350 trans - Sold 2 Jan '08
How to tell if your car is a true SS or not:http://www.chevelles.com/shop/ss_ident.html
Junkyard Dawg is offline
post #2 of 8 (permalink) Old Apr 14th, 08, 10:23 PM
Re: 1970 Chevelle LS6 quarter mile time
Hi Dave,
Fastest recorded ET's for an LS6 car back in late 1969/1970 was 13.20 @ 106 by Super Stock and Car Craft banged a 13.12 @ 107 MPH
All where done on the factory F70 14 tires
Super Stock magazine had a pre-production test mule that they tested in the Oct. 69 issue that turned a 12.69 @113.26 w/slicks and open headers, Auto too.
How is that T-Type treating you?
mr 4 speed is offline
post #3 of 8 (permalink) Old Apr 14th, 08, 10:42 PM Thread Starter
You wouldn't happen to know where I can find a copy of the super stock and car craft runs online would you? I want to use it as solid proof to shut this guy up. Thanks!
It's doing ok. I've not driven it much since I moved out of NC a month ago. I am still having some knock retard issues with it. My fuel pressure is good, I installed a Turbo Tweak chip and bumped up the fuel curves some....and that helped a little, I have a hot wire kit installed, now the next thing I am going to do is drop the tank and install a new Walbro 255 lph pump I have. I am suspecting it might still have the stock fuel pump in it. Next I want to install a new down pipe and exhaust and start looking into getting it ready for the track.
Although I do miss my Chevelle, even though it was a pig at the pump. I even considered trading the T for one if I found one I liked. (probably not gonna happen)
post #4 of 8 (permalink) Old Apr 14th, 08, 10:47 PM
I have the old issues,but no scanner.
show him this:
http://www.musclecargarage.com/50fastestmusclecars.html
Eric's chips rock! (TT)
Don't forget to hot wire the pump too
post #5 of 8 (permalink) Old Apr 14th, 08, 11:45 PM
Like the 'vert!
Here's an LS6 vert 2 years ago at the Supercar reunion...notice the time in the back window...
Bruce
We should take care not to make the intellect our god; it has, of course, powerful muscles, but no personality.
Albert Einstein
http://i19.photobucket.com/albums/b1...n_DSCF3532.jpg SOLD!!!!
Xplantdad is offline
post #6 of 8 (permalink) Old Apr 14th, 08, 11:50 PM
Like the 'vert!
I think it ran low 14's the first run out...
Bruce
Albert Einstein
post #7 of 8 (permalink) Old Apr 15th, 08, 4:24 AM
Rocky
Check this out. Lots of times for old muscle cars,no details on how tests were conducted.
http://roadtests.tripod.com/index.html
Rocky
T.C.#3078
A.C.E.S.#7320
72 Chevelle 402
My Car
VMXRACER is offline
post #8 of 8 (permalink) Old Apr 15th, 08, 8:53 AM
Keith
There can be quite a range in ETs depending on how the same car is set up. Our COPO Chevelle came from the factory with #68 primary jets and #76s in the secondaries. The advance curve didn't come in fully until around 5000 rpm. To say the least it didn't perform all that well and wouldn't launch at all with the no traction F70 X 14 Uniroyals. Just headers, jetting and advance curve changes made it like a different car. Still wouldn't launch at all but sure hauled once it did hook up. Adding slicks would knock several tenths off the et as the higher hp cars could easily lose 3-4 tenths right off the line with stock tires. Magazines tested in various modes, so it is hard to compare numbers without knowing what was done to the car first.
Keith Tedford is offline
This Thread is more than 3331 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
