turbo 350 interchange - Chevelle Tech
post #1 of 10 (permalink) Old Apr 4th, 08, 9:41 PM Thread Starter
Rod
Hey, Just wondering what the difference is between a th350 from a 72 chevelle and one from a 81 camaro? I know the camaro one has an electrical plug on the driver side, don't know what for.
Does anyone know if the camaro one will work in the chevelle?
rbjb99 is offline
post #2 of 10 (permalink) Old Apr 4th, 08, 9:45 PM
Derrick
Re: turbo 350 interchange
it'll bolt in and work, but the 81 model has has a lockup torque converter- which is what the electrical plug is for. i think it is also a weaker trans, and if you get that tv cable out of adjustment, the trans will have a short life.
-Hank Hill
novaderrik is offline
post #3 of 10 (permalink) Old Apr 5th, 08, 12:16 AM
TV cable on a TH350 is just a kick down cable. Line pressure is set by the vacuum modulator, not the TV cable. Plug is for a lock up converter and you can run without it. There is a metric TH350, I believe it is called a TH350C (bot not 100% sure on this).
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
zeke67 is offline
post #4 of 10 (permalink) Old Apr 5th, 08, 2:47 AM
Frank
The C in TH350C indicates a lockup converter.
UGLY '68 Malibu
355, Vortec heads
10.25:1, Comp XE268 FT
TH350, 10 bolt 1 legger
There is No Such Thing as an "ex-Marine."
fj68malibu is offline
post #5 of 10 (permalink) Old Apr 5th, 08, 3:34 AM
Derrick
the question at hand is about the TH350C- which does have a tv cable and not a traditional kickdown cable.
i once had a real odd duck- it was a long shaft TH350 out of a mid 80's 1/2 ton 2 wheel drive pickup that had a TV cable and no plug in it for a lockup converter. i don't know what that thing was actually called, or if it was even any good, but it was weird.
-Hank Hill
post #6 of 10 (permalink) Old Apr 5th, 08, 8:50 AM
Paul
The turbo 350 was available with a six inch (common) nine inch and twelve inch tail housing lengths. In the late seventies and eighties there were also turbo 250C that basically was a turbo 350 with a front band (you will see the band adjustment bolt on the top near the front) that was good for stock use and a turbo 200 that has a one piece case (no separate tail housing) that have a real bad reputation due to the line pressure being regulated by the TV cable and were prone to slipping and burning up.
Paul
prefectca is offline
post #7 of 10 (permalink) Old Apr 5th, 08, 2:47 PM
I learn something every day. Far as I knew, the 350C had the kickdown cable. Gee, I wonder what valve-body passages were changed to accommodate the TV pressure regulation.
Schurkey is offline
post #8 of 10 (permalink) Old Apr 7th, 08, 9:00 PM
I'm with Schurkey on this one. My Hanes book calls the TH350 cable a detent or downshift cable and that the vac modulator line pressure and shift points. It calls the TH700-R4 and TH200-4R a TV cable that combines the function of the vac modulator and downshift cable. It doesn't specifically mention the 350C one way or another though.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
zeke67 is offline
post #9 of 10 (permalink) Old Apr 8th, 08, 6:10 AM
Derrick
head to the closest junkyard and start looking at cars and trucks from the early 80's, and you will find TH350's that have TV cables instead of kickdowns. maybe you'll even find one like the one i mentioned a few posts back with a TV cable and no electrical plug in the side. i think that was still a TH350C- but one of the really early one's that used hydraulic pressure to lockup the converter. the one i had was in an 85 GMC pickup, but who knows if it was original to the truck or not.
-Hank Hill
post #10 of 10 (permalink) Old Apr 8th, 08, 7:11 AM
Originally Posted by prefectca View Post
.....a turbo 200 that has a one piece case (no separate tail housing) that have a real bad reputation due to the line pressure being regulated by the TV cable and were prone to slipping and burning up.
Paul
Ah yes, the turbo 200 slip-o-matic!
If you have a Th350C, I would give it to the junk yard and try to find a non-lockup model. That's just me, though.
68bye is offline
