1970-1972 Chevelle Rear Upper Control Arm Bushing Removal?? - Chevelle Tech
post #1 of 10 (permalink) Old Jun 22nd, 07, 12:54 AM Thread Starter
Hey guys! I have a set of used rear upper control arms, and the bushings are still in them. They are off of the rear end, and I was wondering how I could get the bushings out. I know I can burn them out, but it gets messy. Is there any easier way? Thanks!
Chevelle402ss is offline
post #2 of 10 (permalink) Old Jun 22nd, 07, 1:02 AM
Jason
Send a message via Yahoo to 136679ss
Re: 1970-1972 Chevelle Rear Upper Control Arm Bushing Removal??
Go to Autozone and rent the BAll joint press. Easy as pie, and you get your money back when your done.
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #3 of 10 (permalink) Old Jun 22nd, 07, 1:06 AM
Or, you can use an air chisel and cut them out, damaging the arms in the process... then buy new fancy expensive tubular control arms.
(I think 136697ss has the better answer...)
Stalkingbear is offline
post #4 of 10 (permalink) Old Jun 22nd, 07, 1:10 AM Thread Starter
Thanks for the replies! I'm not sure about stalkingbear's though
post #5 of 10 (permalink) Old Jun 22nd, 07, 1:14 AM
Ya - you can never be sure about what he says or might do....
post #6 of 10 (permalink) Old Jun 22nd, 07, 1:26 AM
Jason
His intent is always good........Well almost always.
TC#2693
Aces# 7467
Heart of Dixie CC
136679ss is offline
post #7 of 10 (permalink) Old Jun 22nd, 07, 6:24 PM
eric
when you press them back in make sure you place a spacer in arm or they will collapse.the you get to buy expensive tubular!!!!!if you paint or powerder coat arms make sure to clean out holes befor pressing in new bushings good luck.
eric
flpackerbacker is offline
post #8 of 10 (permalink) Old Jun 23rd, 07, 12:02 AM Thread Starter
Thanks for the tips!
post #9 of 10 (permalink) Old Jun 23rd, 07, 12:32 AM
Walter
I use a drill with a bit that puts decent size holes in the rubber bushing, and drill holes all the way around to releave the pressure they apply. Then the bushing casing is pretty easy to take out.
Be sure to have your new bushings in the freezer for a couple of days before installation, and don't take them out till you are ready to install. They will slide right in and expand as the defrost.
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
wildman926 is offline
post #10 of 10 (permalink) Old Jun 23rd, 07, 1:47 PM
Throw the bushings in the freezer overnite to shrink them, every thou or two helps.
daveseitz is offline
