cowl hood wireing - Chevelle Tech
post #1 of 2 (permalink) Old May 29th, 07, 6:33 PM Thread Starter
cowl hood wireing
have 1971 chevelle ss with cowl hood, 4 speed.
where do the tan and pink wires hook up on the fuse panel.
also where do the wires that go on the switch that is on the gas pedal.
does it matter which one goes on the top and which one on the bottom of the switch trminals.
thanks much,
bill
BILL TIRELLI
MEMBER#280
1969 BLK CHEVELLE SS396
375HP 4SP 410POSI
1971 BLK CHEVELLE SS402
300HP 4SP 370 POSI
BILL TIRELLI is offline
post #2 of 2 (permalink) Old May 29th, 07, 10:13 PM
Re: cowl hood wireing
Pink from fuse panel to switch, tan from switch to solenoid on cowl hood???
I'm sure there is a "correct" way to connect the wires, but it should work with either wire connected to either terminal.
Schurkey is offline
