70 Wheel question - Chevelle Tech
post #1 of 5 (permalink) Old Jan 10th, 07, 12:17 PM Thread Starter
70 Wheel question
I am looking for some help with my 70 Chevelle wheels. I currently have stock 70 ss wheels which are 14 inch. The current tires on the rear are 275/60/14 which I can not find more accept in bias ply. I would like to put 15 inch ss wheel vintiques on the car so I can put close to the same size radial tire in a 15 inch on it. My quetion is use a 7 inch rim or jump up to an 8 inch. If I use the 7 or the 8 what back spacing works the best. I am trying to not change the current look but also put as much tire on the ground as possible. I think the 15 inch tire in a 275/60/15 is about an inch difference in overall height. Basically, what is the best way to go? I am assuming I will change all the rims to 15 inch not just the rears. Any help would be appreciated! I have tried local tire/rim stores with no help.
MEICH is offline
post #2 of 5 (permalink) Old Jan 10th, 07, 12:38 PM
Greg
Re: 70 Wheel question
You should probably do a search in the tires and wheels section. Alot of discussion on this subject.
I would say the most popular is the 275/60/15. 15X7 would work. But I think the 15x8 with a 3" to 4" BS would be better. I like the deeper wheel look personally.
You also need to consider if the tires will set up inside the wheel wells. Most 275/60 with 3" to 4" BS will. Much bigger than that you may have problems.
TC # 4348
ACES # 6175
NCOA # 10479
"220...221 whatever it takes."
Registry for 68 13867 cars, total to date 169! Looking for more
http://www.chevelles.com/showroom/da...w_2007_019.jpg
http://www.chevelles.com/showroom/data/500/IMG_2694.JPG
ss1970chev454 is offline
post #3 of 5 (permalink) Old Jan 10th, 07, 2:20 PM Thread Starter
Thanks, I quess I didnt scroll down far enough to see that section. thanks I will look their.
MEICH is offline
post #4 of 5 (permalink) Old Jan 10th, 07, 4:57 PM
Ken
MEICH
275-60 x15 on an 8 inch wide rim with less than 4 inches of backspacing will hit on a 1970.Mine did! Unless you cut and roll the inner fender lip, 8 inch wide wheels would be better off with 4 1/2 inch backspacing. Check the Data base.
ken70ss396 is offline
post #5 of 5 (permalink) Old Jan 10th, 07, 9:55 PM
Get Wheel Vintiques series 50 - 15 x 8 with 4.5 backspacing
Summit will have the best price
You'll also want to buy the trim rings from them as well.
They are special for the 15 x 8 wheel
Corvette 15x8 rings will not work
see this thread
trim ring won't go on wheel
Mr69 is offline
This Thread is more than 3758 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
67 Wheel Bearing Question 1967chevelless396 Brakes, Suspension & Steering 2 Dec 21st, 06 3:30 AM
Wheel and tire size question.. mrsuds Wheels & Tires 1 Dec 20th, 06 11:35 AM
Converting 4 wheel drum single master cylinder to 4 wheel disc, brake line question wes migletz Brakes, Suspension & Steering 4 Apr 10th, 06 11:10 PM
Question on wheel spacers/adaptors and powder coating rims Rowdymon Wheels & Tires 2 Mar 13th, 05 9:53 PM
Wheel spacer Question!?!? CHELKAMINO Wheels & Tires 0 Jan 23rd, 05 7:56 PM
