Starter squeal How many shims? - Chevelle Tech
post #1 of 11 (permalink) Old Sep 9th, 06, 8:03 PM Thread Starter
meb
Hi
Hope I'm posting to right group
70 Chevelle 396 Manual Trans - stock application
Put my starter on my 396 as I was getting ready to put the newly rebuild engine in. I noticed with the manual transmission, that is was impossible to see the starter gear and fly wheel alignment. I left things as is.
My GM mechanic neighbor didn't like the sqeal at the very end of the starting cycle. He told me to shim the starter. I put one very thin shim in and it did not do the trick..I now have two shims in and it still has the squeal just as the engine is getting ready to turn over.
What would you folks do? Put another shim or two in and see what happens?
Don't know how many of you have the same stock engine setup that I have, but taking out a starter is a pain...putting in a shim is easy. So what you all say? Go with another shim? Like I said, it is almost impossible to see the gear alignment even with the dust shield off.
Thanks.
meb is offline
post #2 of 11 (permalink) Old Sep 9th, 06, 8:19 PM
Rob
Re: Starter squeal How many shims?
If you look hard enough you can see where to shim it.
Go down to a auto parts store and tell them you need a check pin for your starter and the instruction sheet that goes with it. If you have a auto zone there they will give it to you for free, auto zone puts the instruction sheet and pin in the box with rebuilt and new starters. If any auto parts store can't furnish you with one then somethings wrong.
This pin is round and about four inches long .125 ( 1/8'' ) thick.
Now pull the inspection cover so you can see the starter drive and teeth on the flywheel, carefully take the pin and instruction sheet and see if the pin will slide between the armature shaft and a tooth of the ring gear. The instruction sheet will show you how to shim it and where (get a bunch of shims you'l need them) you can take back what you don't need.
This might take a few times unbolting and reshiming but be patient because if you shim it right it will be quieter and will last a long time, because if you don't you'l be replacing starter drives and sometimes the ring gear (flywheel) gear, been there on ring gears. If this don't get it give me your phone # or call me and I'll take my cell phone and take you through it step by step. Rob
This was an old post, maybe it will help
__________________
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
rubadub is offline
post #3 of 11 (permalink) Old Sep 9th, 06, 8:56 PM Thread Starter
meb
Hi,
Could you explain this one a bit further?
"now pull the inspection cover so you can see the starter drive and teeth on the flywheel"
The stater is the cross bolt type. The application is manual trans with dust shield (which cannot be removed without removing starter). Starter has the stabilizing bolt that attaches to the engine at the back of the starter. This makes if very difficult to manuver the starter much less get it out as easy as, say, my 65' Chevelle with a 283.
meb is offline
post #4 of 11 (permalink) Old Sep 9th, 06, 9:29 PM
Rob
Leave the inspection cover off until you get it shimmed right.
Heres a picture, take a look then let me know if you're okay.
Rob
Re: Starter doesn't always engage
Look at picture # 2 real close, the armature shaft and flywheel, thats the 1/8 pin there using
rubadub is offline
post #5 of 11 (permalink) Old Sep 9th, 06, 9:43 PM Thread Starter
meb
Ok, thanks, I'll have to take a closer look. I'm quite familiar with the shimming process...This is my first manual transmission and I just couldn't figure out how to actually see the gears (flywheel cover on or off).
meb is offline
post #6 of 11 (permalink) Old Sep 9th, 06, 10:09 PM
Rob
It really sucks putting them on and taking them off several times until you get it right, you have to force yourself to do it, I know. If you have a air ratchet it's pretty quick, but hang in there, perseverance is the key.
Another thing that might help you out mentally, and I've been wanting to mention this at different times but never did.
I would be willing to bet that there are others that are learning by this also but are not saying anything, if you look at how many are on line and how many are on the site, I wonder what there doing if they aren't posting.
I know this, because I do it myself.
I'll keep checking back, I go between five different car forums all night long, maybe you'll get it this time, or somebody with a different or better idea helps out.
Rob
rubadub is offline
post #7 of 11 (permalink) Old Sep 9th, 06, 10:52 PM
That drawing in no#2 makes no sense to me at all. Is the gear in the drawing supposed to be the flywheel?
gspan1830 is offline
post #8 of 11 (permalink) Old Sep 10th, 06, 12:14 AM
Rob
Yes thats the flywheel.
On top is the teeth of the flywheel
Under that is the 1/8'' check pin
Under that is the armature.
If it was a true picture, you would see the teeth of the starter, just a little to the left of the 1/8 pin on the armature.
If you look real close in fine print it says what they are right on the picture itself.
Hope this helps.
Rob
rubadub is offline
post #9 of 11 (permalink) Old Sep 10th, 06, 8:17 AM
I've always used an 1/8" drill bit for the pin
My 68 Convertible
383 cu.in
M-20 Muncie
3.36 Posi
Roller Tach
Gravy_D is offline
post #10 of 11 (permalink) Old Sep 10th, 06, 8:54 AM
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
Talking Re: Starter squeal How many shims?
Iam putting mine in today lets see what PITA I run into?
I started with Nothing and still have All of Nothing!
Bad Brads 1969 Convertible SS
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
1badss396 is offline
post #11 of 11 (permalink) Old Sep 10th, 06, 6:57 PM Thread Starter
meb
Problem solved .
In retrospect I would have to say that taking the starter out removing the dust shield, shimming and reversing the process in my 70' 396 Manual trans would have taken forever. You guys know what I'm talking about right? I'm not lazy at all; damn starter hits against the the frame and the dust shield gives you no manuverability. god forbid you want to take the electrical off.............ahhhh
I must confess that I simply took out the thin shims provided to me by the starter manufacturer and put in a 1/16th inch shim and the problem is about 95% cleared up. I'm going to give it a week or two before I decide to shim it any more, that's how confident in the repair.
Putting the shim in was not an easy task. It is more of a problem that the starter fits almost EXACTLY into the dust shield. After removing the one bolt (cross pattern starter) and lossening up the other (and the support bolt on the back of the start that attaches to the block) it was a little tricky getting that 1/16" shim in. A simple pry (lightly) with the back of a screw drive got the holes lined up.
Always appreciate the support here, there really are some good folks on this web site.
http://home.comcast.net/~meb
meb is offline
This Thread is more than 3882 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Startermania! malibu man, Reno 1, and mbu65ss vs. their starters: Chapter 2 LouieHammel Troubleshooting 55 Oct 7th, 07 3:24 PM
Starter Problems rich1978 Performance 5 Jan 20th, 06 8:07 AM
Max number of starter shims? Now clicking!!!!!! german Engine 3 Sep 29th, 03 1:37 AM
Won't Start when hot 67SS_MASS 2003 15 Jul 24th, 03 11:20 AM
weird "short", or "open", or ?.......... mikeclam Electrical & Wiring 19 Feb 13th, 03 10:17 AM
