fuel sending unit - Chevelle Tech
post #1 of 4 (permalink) Old Mar 30th, 06, 5:26 PM Thread Starter
Send a message via AIM to crazyredneck
fuel sending unit
does anyone know how to get the sending unit out of the gas tank?? i dropped my tank the other day and wanted to look at the sending unit before i put it back in.
crazyredneck is offline
post #2 of 4 (permalink) Old Mar 30th, 06, 5:42 PM
Re: fuel sending unit
not 100% on others but on the 70 to 72 there is a ring that has ears on it that you carefully tap to unscrew. the ring comes off the and the sending unit lifts straight out. There is a rubber donut gasket that seals it. It only rotates about a 1/4 turn. BE CAREFUL, no sparks with fumes around.....
Rick Smith
former MCC # 448 member
former TC # 1549 member
former ACES member, sorry it went under
1972 Chevelle 427, T-56 6 speed
1970 Chevelle project 3/4 complete. 383, powerglide
Professor_SS is offline
post #3 of 4 (permalink) Old Mar 30th, 06, 6:27 PM
"Wild Bill"
Rick's correct except for one thing...it doesn't lift straight out. You'll have to watch because when the sending unit/pick up is about halfway up out of the tank, you'll have to turn it on an angle in order for the gauge float and the pickup sock to clear the hole.
Just go slow and easy and you'll see...
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #4 of 4 (permalink) Old Mar 30th, 06, 7:56 PM
Tim
Send a message via Yahoo to 69Malibuman
I just replaced my sending unit. The pick-up sock looked fine on my old one but after gently squeezing it a couple times it fell apart it was so brittle. May want to check it while you got it apart. Also they make a special tool for taking off that ring. I don't know who has them but it sure would be safer than a hammer and screwdriver. NAPA may carry them. Tim
69Malibuman is offline
