1967 Steering Column Bearings - Chevelle Tech
post #1 of 7 (permalink) Old Feb 13th, 06, 10:34 AM Thread Starter
Raymond
Send a message via Skype™ to 67Chevelleman
Does anybody know where I can get the Bearings or know the part # of the Bearings in 1967 Steering Column.It is Floor Shift and Non-Tilt.
Thanks,Raymond
67Chevelleman is offline
post #2 of 7 (permalink) Old Feb 13th, 06, 1:59 PM
Re: 1967 Steering Column Bearings
For the bottom ball bearing, I just measured the inside and outside bearing dimensions. I then went to the local farm store and picked up a sealed roller bearing for about $5 and slid it on, I then put on the bottom hardware and clip. Easy, simple, cheap fix that is better than the original.
66BBCONV is offline
post #3 of 7 (permalink) Old Feb 13th, 06, 2:38 PM
I posted these numbers a while back and heard that they were still good GM numbers. They were for a 65 but think they are the same.
Upper 5679205
Lower 7802845
Cam
Cam Sweet is offline
post #4 of 7 (permalink) Old Feb 13th, 06, 2:39 PM Thread Starter
Raymond
Bill,
I never thought of that,thanks
post #5 of 7 (permalink) Old Feb 13th, 06, 2:45 PM
Those 64-66 numbers will not fit 67-68....
This is what I show W/O tilt
67-70 upper bowl bearing 7800269 (still good GM number)
67-68 lower bowl bearing (plastic?) 7800528 available NOS dealers only
67-68 lower shaft bearing 7802186,7804200,7806142 superceeded numbers. NOS dealers only
Rene
66_Malibu
shooter is offline
post #6 of 7 (permalink) Old Feb 13th, 06, 2:47 PM Thread Starter
Raymond
Cam,
I will certainly check into these numbers
Thanks a lot, Raymond
post #7 of 7 (permalink) Old Feb 13th, 06, 6:21 PM Thread Starter
Raymond
Thanks Rene for all the info
