Fuel guage problem - Chevelle Tech
post #1 of 5 (permalink) Old Oct 30th, 05, 8:09 PM Thread Starter
Fuel guage problem
I have just started my 69 chevelle after dropping the fuel tank for cleaning. The problem is that with approximately a half tank of gas the guage reads far past full. What's up?
Ed Hobbs
Ed.Hobbs is offline
post #2 of 5 (permalink) Old Oct 30th, 05, 8:34 PM
Re: Fuel guage problem
Did you disconnect the battery before dropping the tank? If not, you shorted out the sending unit when you reconnected the wires to the tank. How do I know? I did the same thing you did. Be sure to connect the ground wire first then the lead going to the gauge and last the battery.
SS496 is offline
post #3 of 5 (permalink) Old Oct 30th, 05, 8:39 PM Thread Starter
The battery was disconnected prior to the drop. The needle stiil moves from the full mark with ignition off and then increases with ignition on!
Ed Hobbs
Ed.Hobbs is offline
post #4 of 5 (permalink) Old Oct 30th, 05, 8:53 PM
I would check the ground wire for a clean contact with the body. You can check the gauge by connecting two d cell batteries to it. This should show a half full reading if the gauge is still ok.
SS496 is offline
post #5 of 5 (permalink) Old Oct 30th, 05, 9:00 PM Thread Starter
Great suugestions. I'll do that first thing tomorrow. Thanks
Ed Hobbs
Ed.Hobbs is offline
This Thread is more than 4226 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Gas guage jayhawkclint Electrical & Wiring 5 Nov 5th, 07 10:01 AM
fixing a fuel neck problem james a larson Body Shop 7 Sep 22nd, 05 11:23 AM
What could be the problem, fuel leaking from secondary throttle shaft james a larson Engine 6 Apr 17th, 05 4:20 PM
Fuel Geyser problem RedHot66 Troubleshooting 2 Jul 13th, 04 6:45 PM
problem with fuel gauge My_72_Malibu Electrical & Wiring 4 Apr 23rd, 01 7:33 PM
