Upgrading my '65 El Camino - Page 3 - Chevelle Tech
SS396.com and GROUND UP, The Source for 64-72 Chevelle Restoration Parts
Find El Camino Parts at SS396.com
GROUND UP & SS396.com
Official Sponsor of Team Camino
Have Bed .... will travel.
El Camino Tech
El Caminos El Camino & Sprint
Old May 8th, 12, 8:59 AM   #31 (permalink)
GBJ
Re: Upgrading my '65 El Camino
So close
Interior just needs seat installed.
Yesterday got brakes bleed -- cooling done (hoses, fan, spacer, clutch, A/T lines) .
It was late and I haven't added water to check for leaks and didn't want to find any as I would have kept working.
Also no pics yesterday.
Hopefully today I get coolant in and checked out thet I can let engine run for longer the 15-20 second as I have been doing. Then I can hook up timing light & vacuum gauge and get everything tuned.
I think it will take a week to clean and polish everything.
More photos Click Here
George
Flaming River Collapsible Shaft
GM Sport Wheel "RED"
Needs Cleaning
__________________
Click on below for more info
My Web Site
1965 El Camino
1965 Corvette
1931 Ford Roadster
GBJ is offline   Reply With Quote Quick reply to this message
Old May 8th, 12, 11:01 AM   #32 (permalink)
Gorgeous! Can I borrow your bank account. My wish list has doubled and all my plans have changed since your inisial post. My El is about were you started. Great job!
__________________
65'el camino 360 10.5/1 750DP holly 7501 air gap M21 4sp 3:73 black on black
Never sell your stuff.....takes 30yrs to get it back.
<a href="http://s909.photobucket.com/albums/a...5elcamino2.jpg" target=
Can-Am #305
El Toro is offline   Reply With Quote Quick reply to this message
Old May 8th, 12, 3:55 PM   #33 (permalink)
GBJ
2nd post today (see above) BUT I'm 99% done
Added water and started ELKY --- No leaks --- Let it run and check timing which was dead on which was a 1st for me in all the years always need a little tweeking. Continued to let it idle and temp stay at 180° even with A/C on.
Need to re-bleed brakes -- seem kind of mushy.
Also spotted leak under transmission in the vacinty of cooling lines BUT I think it probably is the NEW Flex-Dip-Stick seal. Even with gobbs of sealant I would put my $$$ on it.
Need to fabricate a bracket for the heater & A/C hoses on right fender well. Then hood & seat and a big clean job.
More pic on web site ==> Click Here
Now it's grass-cutting time
George
__________________
My Web Site
1965 El Camino
1965 Corvette
1931 Ford Roadster
Old May 12th, 12, 2:38 PM   #34 (permalink)
GBJ
Still need to bolt hood on and clean-clean-clean plus there are a few other
minor details I will get to next week BUT I'm done
Haven't driven yet, other then 6" forward & 6" back Perhaps later today after my son stops by to help me remove hood from A$$ end I will take it on its maiden voyage.
George
More pics
Did I mention it needs a GOOD cleaning
__________________
My Web Site
1965 El Camino
1965 Corvette
1931 Ford Roadster
Old May 13th, 12, 11:32 PM   #35 (permalink)
Banned
What steering wheel is that? What did it take to mount it? I want that style for my 65 el camino. Looking good.
sschevellefan is offline   Reply With Quote Quick reply to this message
Old May 15th, 12, 1:14 PM   #36 (permalink)
GBJ
GM Sport Wheel - Found on late 60's & Early-mid 70's Chevy, Olds, Buicks & C3 Corvette. Also called comfort grip. Colors were black, tan, red & blue (I think that was all).
Need matching hub and horn contact & button
Usually found on Ebay -- gettnig pricey.
BTW-- I have a Tan one with hub, contact & button off of a buick.
George
Old May 22nd, 12, 11:23 AM   #37 (permalink)
This Elky is making me seriously reconsider my planned direction with mine. Really nice car.
__________________
TC Member # 4431
'04 Ram Quad-That thing has a Hemi in it!
'68 El Camino-SB 350/TH400/???
'67 Hell Camino-BB 496/TH400/???
'55 BelAir 2 door post-427/TH-400/4.10
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
badrad is offline   Reply With Quote Quick reply to this message
Old May 27th, 12, 2:22 PM   #38 (permalink)
GBJ
After a few days of tuning and adjusting finally put the hood back on
Have been driving, couple of cruises, one long test run and a few to-store-and-backs. Only problem(s) was one small water leak (loose heater hose clamp). And one BIG problem -- had a major FLAT spot coming off idle and/or low RPM. Timing was dead on as was vacuum advance. The intake and carb (Holley 670 Avenger) we previous on my '65 Vette and didn't give me any problems. However, the carb had sat for a while and the accelerator pump had dried out, replace it and improve somewhat. Did vacuum test and it was a little almost same as Vette only difference was Vette is 5 speed manual and ELKY has turbo 350 and I think the I probably feather the clutch a litte with this set up on the Vette. Determined that the original power valve “6.5” was a bit to strong so bumped up the a 7.5 and like magic the FLAT spot was gone. During all this time I also swapped out the jets to improve performance and along with new Mallory Unilite distributor, new plug wires & plugs I now have steady pull all the way up through 5000 RPM (that’s a high a I’ve tried) with out a mis-fire or sputter.
On my longer test run which was Interstate ~65 MPH with cruise-control on – then stop-and-go – then some good old Missouri twisty back roads everything seem to work just fine. So I can finally same “I’m Done” --- NOT really because these cars are NEVER DONE
One other note is that even with A/C on and HOT weather water temp stayed very close to 180 -- Thanks Alumitech
George
__________________
My Web Site
1965 El Camino
1965 Corvette
1931 Ford Roadster
Old May 27th, 12, 4:30 PM   #39 (permalink)
Awesome! I've thoroughly enjoyed following your improvements.
You're way too organized, George. Shops shouldn't be that neat. :-)
300Deluxe is offline   Reply With Quote Quick reply to this message
Old May 28th, 12, 12:58 AM   #40 (permalink)
What sort of modifications did you have to make in order to accomidate that kick panel speaker and the parking brake lever? Thats exactly the sort of thing I have been trying to figure out and have a few ideas in my head.
__________________
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline   Reply With Quote Quick reply to this message
Chevelle Tech > Specialty > El Caminos      Current Topic: Upgrading my '65 El Camino
Insurance
Please select your insurance company (Optional)
First Name
It's always nice to know a name instead of Mrhot67ss
» Premium Vendor Showcase
» Buyer's Resource
» Recent Discussions
RIP Gregg Allman
Today 4:04 PM
Last post by Alan F
Today 7:13 PM
4 Replies, 76 Views
2017 Northern Ohio...
Sep 16th, 16 9:27 AM
Last post by FLASHED
Today 7:06 PM
105 Replies, 5,263 Views
MSD Distributor Issues
Today 9:54 AM
Last post by Saltherring
Today 7:05 PM
3 Replies, 74 Views
How come no 20's or 22's?
Jun 13th, 11 4:53 PM
by JBC90GT
Last post by Brownd3max
Today 7:05 PM
140 Replies, 67,279 Views
A "survivor" (some...
Yesterday 5:26 PM
Last post by swilk427
Today 6:53 PM
108 Replies, 1,813 Views
Bolt in axle Question -...
Today 6:46 PM
by mjblum
Last post by mjblum
Today 6:46 PM
0 Replies, 22 Views
70 - Fried fusible link...
May 21st, 17 12:32 PM
Last post by Birddog1970
Today 6:45 PM
29 Replies, 572 Views
HOLLEY SNIPER EFI TUNING...
Dec 11th, 16 1:37 AM
Last post by rel3rd
Today 6:30 PM
267 Replies, 19,853 Views
1970 SS Wheel / Tire...
Today 6:23 PM
Last post by vinnievega
Today 6:23 PM
0 Replies, 16 Views
Looking for TC member...
Today 3:40 PM
by Duane_D
Last post by Bonkerman
Today 6:01 PM
3 Replies, 94 Views
Powered by vBadvanced CMPS v3.2.3
Is there a site like this for?    El Caminos Camaros Novas Impalas GTO Chevy Punch All Chevys
© 2009 Team Chevelle - AutoForums
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
