1968-72 GM A-body inner fender ??? - Chevelle Tech
SS396.com and GROUND UP, The Source for 64-72 Chevelle Restoration Parts
Find El Camino Parts at SS396.com
GROUND UP & SS396.com
Official Sponsor of Team Camino
Have Bed .... will travel.
El Camino Tech
El Caminos El Camino & Sprint
Old Jul 4th, 10, 5:56 PM   #1 (permalink)
mr
Originally Posted by L7870_cortez View Post
El Camino fenders, are not the same as Chevelle fenders.
1970 El Camino fenders are one year only.
Originally Posted by Diamond Judge1 View Post
It makes perfect sense that they would do this. Making fenders to fit the contours of the old 1968-69 body style, was a lot cheaper than re-designing the doors and quarters of the new models.
Only required making dies for the fenders, when the other way required making dies for fenders, doors, and quarters. GM must have saved lots of money this way.
Jeff Dotterer
Dated Components
Diamond Restored Judge
Originally Posted by Robinls5 View Post
TWO pieces of sheet metal that will interchange from a 1970 Chevelle and a 1970 El Camino.
Any 1970 hood will fit " El Camino & Chevelle ", also the painted filler pan between the bumper and grill.
Also a 1970 Chevelle remote mirror will not work on a 1970 Camino, different shape on the doors.
Originally Posted by prefectca View Post
Actually, the inner fenders will work also.
I'm curious, if "any other 1968-72 GM A-body inner fenders" will fit a 1970 El Camino ???.....
__________________
__________________________________________________
....... "drag racers do it , till their rubber smokes" .....
mr is offline   Reply With Quote Quick reply to this message
Old Jul 4th, 10, 6:31 PM   #2 (permalink)
Re: 1968-72 GM A-body inner fender ???
The inner fender wells for 68-72 are the same for Chevelle and Elcamino.
RealRed70 is offline   Reply With Quote Quick reply to this message
Old Jul 5th, 10, 3:38 AM   #3 (permalink)
This is not entirely true.
The RH 1968 metal inner fender on cars with AC is a stand alone. There is a hole for the AC hoses to go thru and uses a rubber grommet where they pass thru. Metal LH is same for 68-72.
1969-72 Metal L and R inner fenders are all the same. AFAIK
1968-69 plastic inner fenders are different than the 70-72. 68-69 do not have the flange above the upper control arm.
All above will bolt up and fit properly to any model 68-72 Chevelle.
Mr69 is offline   Reply With Quote Quick reply to this message
Old Jul 6th, 10, 2:29 PM   #4 (permalink)
They fit 70-72 Monte Carlos as well. That's where I used to get my steels from, 68-70 Chevelles.
chevygod is offline   Reply With Quote Quick reply to this message
Old Jul 6th, 10, 9:10 PM   #5 (permalink)
mr
Thumbs up Re: 1968-72 GM A-body inner fender ???
Thanks for all the info, guys ....
I need to find a metal "passenger side inner fender", to replace a busted up plastic one .....
on a 1970 El Camino.
I know where a couple of complete 4-door 1971 Chevelle's are, a 1969 GTO hull w/metal inner fenders- still intact, and possibly a 72 Monte Carlo junker prospect ...
I am also curious, about the possibilty of other 1968-72 GM A-bodys such as,
-Buick Skylark-
-Pontiac GTO-
-Oldsmobile Cutlass-
.... inner fenders being from the same GM mold, as the El Camino & Chevelle inner fenders .... just a thought.
__________________
Old Jul 6th, 10, 9:35 PM   #6 (permalink)
From my searches for my Monte's (back in the 80's!), it was 68-70 Chevelles-El Caminos that would work. Steels didn't show up in 71-72 Chevelles I saw and I didn't see them stock in any Monte Carlos. I did try some other GM A-body inners with no luck. The hole for the AC in the 68's didn't seem to matter in my Monte, so may not matter in a Chevelle either.
Old Jul 7th, 10, 6:23 AM   #7 (permalink)
-Buick Skylark-
-Pontiac GTO-
Nope
the BOP cars are different. Way different.
The 71's you know of prob have plastic.
Old Jul 7th, 10, 9:04 AM   #8 (permalink)
mr
Smile Re: 1968-72 GM A-body inner fender ???
The 1971's you know of probably have plastic.
Thanks again, guys ... looks like 1969 or 1970 Chevelles/El Camino only for metal .... and possibly 1968 ...
My grandson's, stock appearing un-restored, Van Nuys built 1970 El Camino has a steel drivers side, and a plastic passenger side inner fender ....
My 1970 Chevelle coupe built at Leeds, has both steel inner fenders ....
__________________
Old Jul 7th, 10, 12:08 PM   #9 (permalink)
Ya'know, I seem to remember seeing plastic/steel mixes in the yards back when, but I thought it was from a repair of a car after body damage, and a plastic inner was installed by the body shop. They seemed to be either/or, not all one side like a plant running low on one side. I always bought them in matched sets, so wouldn't look at these too closely.
Thinking on this subject, I also recall seeing a car with a driver-side inner that was fiberglass, looked like the marbled grey material used on older Vette bodies. It looked too nice (ie heavy construction, so not a lightweight racing part) to be aftermarket. It was only the one side, so I passed it by. Anyone know of these?
Old Jul 16th, 10, 11:52 AM   #10 (permalink)
JPS
I have a 70 EC, Fremont build with plastic inner fenders [which are torn at the mount flange so I will need to replace soon]. I bought the car [truck] from the original owner and never had reason to believe that it was in a front end collision. So, my presumption is that for this particular EC Custom, it rolled out of Fremont w/plastic inner fenders.
Hoping to replace w/metal- don't like the plastics.
JPS is offline   Reply With Quote Quick reply to this message
Chevelle Tech > Specialty > El Caminos      Current Topic: 1968-72 GM A-body inner fender ???
Insurance
Please select your insurance company (Optional)
First Name
It's always nice to know a name instead of Mrhot67ss
» Premium Vendor Showcase
» Buyer's Resource
» Recent Discussions
DIY painting -...
Today 10:37 AM
Last post by markd234
Today 10:37 AM
0 Replies, 3 Views
Opinions-Undercarria...
Yesterday 11:18 PM
by DS1980
Last post by brent kuz
Today 10:36 AM
10 Replies, 162 Views
555 pump gas dyno guess
Yesterday 11:07 PM
by sick71
Last post by Lew540
Today 10:35 AM
6 Replies, 139 Views
1970 NOS hood style
Today 10:34 AM
Last post by NGChevelle
Today 10:34 AM
0 Replies, 11 Views
NASCAR Changing Points &...
Yesterday 1:28 PM
by jfkheat
Last post by Aaron
Today 10:31 AM
13 Replies, 212 Views
Pics of a 2" dropped 67...
Jan 21st, 17 9:31 PM
by Aaron
Last post by Kirk's67SS
Today 10:31 AM
10 Replies, 235 Views
Engine won't fire up,...
Jan 20th, 17 8:09 AM
by M1ke
Last post by M1ke
Today 10:18 AM
36 Replies, 684 Views
restoring tail lamp lens
Jan 20th, 17 9:39 PM
Last post by keithb
Today 10:13 AM
4 Replies, 186 Views
66 willow green SS in MI
Yesterday 11:02 AM
Today 10:12 AM
6 Replies, 280 Views
White Vinegar rust...
Today 12:18 AM
by RAMBO
Last post by joeyv69ragtop
Today 10:12 AM
2 Replies, 79 Views
Powered by vBadvanced CMPS v3.2.3
Is there a site like this for?    El Caminos Camaros Novas Impalas GTO Chevy Punch All Chevys
2009 Team Chevelle - AutoForums
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
