"Basics of Basics" top pump/motor disassembly and rebuild. - Chevelle Tech
Convertibles Convertible Q & A's
 2Likes
post #1 of 27 (permalink) Old Apr 16th, 12, 1:37 AM Thread Starter
“Basics of Basics” Convertible top pump/motor rebuild
By Brian Martin
This “Basics” is more about demystifying the convertible pump system than anything else. I got the pump/motor back in my car and working so fast and with such excitement that I didn’t take any photos at all. So in deciding to put together a little “Basics” on the subject I just went and snapped some shots of the extra pump/motor I had. When I decided to pull mine apart I did a little google search and found nothing what so ever, thus the need for this “Basics”.
Where it all began…..I was putting my 1965 Buick Gran Sport convertible back together after about 12 years apart. Everything was finished on the car and being I am no mechanic I did the body and paint and left the convertible top stuff for the very end. To tell you the truth, I was pretty intimidated by it, but finally dug into it. The first thing I did was to install the rams that I purchased 12 years ago. The system worked when I pulled it apart and I forget why I even bought the new rams but I had them non-the-less. I got the motor and lines out of the rafters and blew out the lines with compressed air after removing them so I wouldn’t be dripping brake fluid all over my beautiful paint. I installed the rams and pump/motor and put in some new brake fluid (I HATE working with this stuff around paint!) and hit the switch……nothing. I mean nothing what so ever, not even a sound. After some diagnosis work I determined the pump/motor was the problem so I started thinking about buying a new one, which I found out was a off shore “generic” and I wasn’t going to have any part in that. And me being cheaper than snot I figured, I would pull the thing apart and see what it’s all about. I had a spare (a little newer, it had a rubber fill plug instead of the screw the original had) and decided to learn on the spare. These photos are of the original pump/motor so you will see the screw in fill plug in photo #2. We start with photo #1, these are the two bolts that hold the motor onto the pump. They are a ¼” headed bolt about 4 inches long that goes right past the magnets on the sides of the armature and screw into the pump body.
In photo #2 you can see the standard screw driver headed fill plug and the bolt that holds the reservoir to the pump. It’s simply an approx 3” long bolt that goes thru the middle of the reservoir into the pump. That bolt head looks pretty odd but a regular 11/16 open end wrench works on it.
The reservoir has a large O ring that seals it, (seen in photo #16) and a small O ring at the head of the bolt. (Photos# 16 & 17). When you remove that bolt and pull the reservoir off you will find the top of the pump as seen in photo #3. Remove the five quarter inch 7/16” headed bolts and you will have photo #4 and the pump it’s self photo# 5. You my have noticed if you looked at the photos that there is no gasket, it simply bolts right to the pump with the two aluminum surfaces being perfectly flat.
Photo #6 shows two of the only four moving parts in the pump (it’s crazy simple guys). I honestly don’t know what to call them. The larger ring looking piece goes in the hole in the pump, while the little star looking piece slips into the ring and over the end of the armature seen in the pump, refer back to photo #5. I ended up using parts from both pump/motors to make one. The ring thingie you see was so stuck in the replacement pump that I couldn’t get it out. I pulled the one out of the car at that point so I could get them both apart and see what parts I need. I ended up hammering a bolt into that ring so I could twist it and get it out of the pump. If this was the only one I had, I would have had to find another way. But to tell you the truth, I tried quite a bit before I resorted to the bolt. You can’t see it in the pictures because I have the bad part facing down. But I did ruin this piece. The original pump was stuck too, but I was able to get the piece out after a little coaxing. This was why the original motor didn’t turn. The pump was locked up solid! I have to assume the “rebuild kit” they sell for these motors would include this ring and star piece.
You can see the two ball bearings that go in the pump cover in photo #7. These ball bearings are what controls the fluid, directing the fluid to the hoses that will carry it to the bottom of the rams raising your top, or to the hoses that will carry the it to the top of the rams lowering the top.
In photo #8 you can see the round hole where that ring and star sit and the little O ring that seals the armature shaft as it comes into the pump. You can also see the passages that the fluid goes thru being pushed by the pump into the respective hoses.
These passages need to be cleared. They will likely have crusty gunk in there from loose chunks that fall right out to rock hard stuff that needs to be “chiseled” out with a sharp tool. Breaking this junk up and blowing it out with compressed air works like a charm. Cleaning out all the junk in these passages, where the two ball bearings are, and replacing the O rings at the armature, hose fittings, and if you want the reservoir and fill plug is all there is to “rebuilding” the pump! That’s it guys, it is that easy!
On to the motor portion and photo #9. After removing the two long bolts mentioned in photo #1 the motor pulls off the pump. Those two screws are the only thing holding it on. There is no gasket or seal, it simply pulls off easily. You can see in the photo a small washer on the armature (a rusty washer in this case), that is one of only four pieces that come out of the motor. Photo #10 shows the end of the motor with the brushes, and photo #11 shows the ball bearing that sits in the end of the armature and a little disc that sits at the bottom of the hole the armature goes in and the bearing rides on it.
To be continued...
Brian Martin
1965 Buick Gran Sport Convertible
1959 Rambler American. Yeah, I said RAMBLER, you want to make something of it punk?
"Fan of most anything that moves human beings"
MARTINSR is offline
post #2 of 27 (permalink) Old Apr 16th, 12, 1:38 AM Thread Starter
Re: "Basics of Basics" top pump/motor disassembly and rebuild.
Continued from previous post...
To put the motor back together you have to be able to hold the brushes back to slip the armature in. The little disc can simply be dropped into place, the bearing I put a tiny bit of grease on it to hold it to the armature so insure it was in correctly. The next thing is those darn brushes, I got two paper clips and bend them as shown in photo #12. Obviously this isn’t rocket science so they look quite different from one an other but did a perfect job. As seen in photos #13-A and 13-B. Photo #14 shows the motor with the armature in place with the paper clips still there. After this point, you simply pull the paper clips out and there you have it.
The bolts that hold the motor together are honestly the only tough part to reinstall. You have to play quite a bit (at least I did) before I could get those buggers started into their threaded holes. Photo #15 shows how they pass thru the motor right next to the magnets. Sorry for the poor photo I just wanted to add it to demystify this darn bolt. You can see at the top of the photo a little half round pocket in the magnet where the bolt fits down to the pump on the other end of the motor.
Photo numbers 16, 17, 18 and 19 simply show the seals that are in the pump/motor assembly. I found them all in the A/C O ring assortment at the parts store. The large one I found that goes around the motor was smaller than the original and would have stretched out and worked but I just left the original there and it worked like a charm.
This is what the pump reservoir looked like on my original pump! Darn good thing the motor and pump didn’t work or I would have pumped this crap into my new cylinders!
Yes it is a darn good thing I went ahead and pulled the pump apart and rebuilt it. It worked the first time I tried it, just hooked it back up and turned the switch and wham, I had a working top pump/motor again. The other very good thing that came from it was I changed it out to run automatic transmission fluid, I am MUCH happier with something that won’t eat any paint like aircraft paint stripper!
It was also learned that these motors are very generic and all cars made for a number of decades from all manufacturers have very similar pump/motors.
I can’t believe that I was so intimidated by this whole thing, it was so damn simple I was blown away. I had it back and running in the car so fast I didn’t even have time to think. Now darn it, go out there in the garage and get yours working, it’s almost summer!
Brian Martin
MARTINSR is offline
post #3 of 27 (permalink) Old Apr 16th, 12, 2:40 AM
Nice write up Brian. The pump part looks like a mini power steering pump.
Boldly going nowhere
72 Concours Wagon More go, more whoa and lots of creature comforts
64 Nova 400 series
Team Chevelle Gold Member #42
Philip is offline
post #4 of 27 (permalink) Old Apr 16th, 12, 10:53 AM Thread Starter
Thanks, Brian
Brian Martin
MARTINSR is offline
post #5 of 27 (permalink) Old Apr 18th, 12, 1:11 PM
your also missing photos 16, 17, 18. did you find a source for the brushes and other parts for the motor? also i noticed you didn't mention anything about a seal kit? is this something i would need? heres an example
http://www.hydroe.com/product_detail...p%20Seal%20Kit
bigsexy408 is offline
post #6 of 27 (permalink) Old Apr 19th, 12, 2:33 AM Thread Starter
Here are those photos.
I didn't mention anything about a seal "kit" but did say that I found the seals I needed at the local parts store in the A/C seal assortment.
I can't imagine needing brushes, mine where very long in both motors. I know that my car's top went up and down all the time, I am talking many times over and over, on a rainy day when the clouds parted I'd drop the top I can't imagine wearing those brushes out.
Brian Martin
MARTINSR is offline
post #7 of 27 (permalink) Old Apr 19th, 12, 2:11 PM
Terrence
Can we get a sticky on this ? Great job. I'm gonna need in a few years!
69 Chevelle Convert
Kaizen is offline
post #8 of 27 (permalink) Old Apr 20th, 12, 3:34 PM Thread Starter
Ok, off to the cylinders!
A number of people requested a "demystification" of the cylinders. Well, I was going to toss them and I am glad I didn't. I certainly don't have any knowledge in the subject so what you see is what you get.
Starting with photo B you will see that cut a slit around the tube that makes up the cyl. I should have taken a better photo before I did this but was so damn excited to cut it open and see what was inside.
It is crimped at the top, pretty tough to reproduce this at home. I am thinking that you could possible make a pair of dies that could do this in a vice. But it's asking for a lot, pretty tough to pull it off if you ask me.
Photo C is a close up of the "piston" in the cyl.
Photo D shows me prying the top of the tube off the upper piece. And E shows what the piece looks like when off.
And G shows the assy overall. There is no "F" photo so don't think I there is one missing. I messed up when I was putting the letters on them.
Photo H shows how the tube would go back onto the upper piece if you wanted to try crimping it.
To be continued......
Brian Martin
MARTINSR is offline
post #9 of 27 (permalink) Old Apr 20th, 12, 3:36 PM Thread Starter
continued from previous post....
I cut the bottom of the tube off so it can be seen.(photo I) The hose hooks to the side of that "donut" area inside. The nut and then end of the rod goes down into that area in the middle of the donut when it goes all the way down. This is one thing I wonder about, if you were to cut the tube off like I did and re-crimp it, it's going to be a quarter inch (or so) shorter, will this interfere with the operation of the cylinder? Photo J shows the two side by side, will the shortening effect it, I am thinking not, but I don't know.
Photo K shows the piston and the O ring seal.
The top piece of the cylinder shows a snap ring that needs to be removed to get the seal out as seen in photo L. The seal is an odd one, it's like a hollow washer with a plastic like washer inside. I am assuming this is needed for the high pressure that it is subjected to.
In photo L you can also see the O ring that goes around the top of it to seal the tube when it is crimped on.
I don't know guys, if you are willing to try rebuilding one, you are tougher than me. I would still buy new ones and spend that time on getting the car done, it's almost summer!
Brian Martin
MARTINSR is offline
post #10 of 27 (permalink) Old Apr 21st, 12, 12:38 PM
Pete
Great writeup Brian! And just in time for me too! I was starting the pump rebuild today!
Thank-you~!
pete
Former A.C.E.S. #06507
TC: #2529
68 Convertible (rising from the ashes of neglect)
68Phoenix is offline
post #11 of 27 (permalink) Old Apr 21st, 12, 12:58 PM Thread Starter
This is why I did it! When I went to pull mine apart I got on the net and couldn't find a darn thing on these pump/motors, not a single photo of what I was going to find when I opened it. There you go and have fun! I am out to the garage right now to see if I can get the top irons sand blasted and painted today.
DrScotti likes this.
Brian Martin
MARTINSR is offline
post #12 of 27 (permalink) Old Jun 27th, 13, 12:40 PM
This should be a sticky!
-Joe
Team Chevelle #2680
'69 Malibu Convertible
- Official Build Thread!
http://www.facebook.com/unkinjoe
joeyv69ragtop is offline
post #13 of 27 (permalink) Old Jun 28th, 13, 10:58 PM
Great write up, if people only new how easy it was to restore these pumps. I restored my original Delco unit over the winter with a Hydro-E-lectric rebuild kit. Very inexpensive!
And the generic pumps do not resemble the orignals. A real standout on a stock resto
Before and after pics
ID:	93713   Click image for larger version
ID:	93721   Click image for larger version
......._________
.../ /__________\ \
</______________\>
..| O O __ss__ O O |
..\_____|___|_____/
....|__|. . . . . .|__|
1971 Chevelle Super Sport convertible
(Body-off / Documented Matching#s w/3 Build Sheets)
http://www.fquick.com/garages/viewga...=1&carid=56357
K.R.Joye is offline
post #14 of 27 (permalink) Old Oct 26th, 13, 11:34 PM
Send a message via AIM to jnorth
Stickied
Jim North
71 Chevelle Convertible BBC
72 El Camino
ACES#4927 TC Gold #1404
Support your local Chevelle club!!
jnorth is offline
post #15 of 27 (permalink) Old Jul 10th, 14, 9:08 PM
Pete
OKAY, I have a question. What are the torque settings for the hoses? every connection? I have mine set where I THINK they will be okay, but don't want to take chances.
pete
TC: #2529
