"Basics of Basics" top pump/motor disassembly and rebuild. - Page 2 - Chevelle Tech
Convertibles Convertible Q & A's
 2Likes
post #16 of 27 (permalink) Old Jul 11th, 14, 12:01 AM Thread Starter
Re: "Basics of Basics" top pump/motor disassembly and rebuild.
Never even thought about it, I went by "tight".
Brian Martin
1965 Buick Gran Sport Convertible
1959 Rambler American. Yeah, I said RAMBLER, you want to make something of it punk?
"Fan of most anything that moves human beings"
MARTINSR is offline
post #17 of 27 (permalink) Old Jul 13th, 14, 1:21 AM
AKA Zombietroll
Was there a typo? Just wondering in the writeup the op said he used break fluid in the system?? I've always used trans fluid but hydrologic oil from tractor supply will do also. Would think break fluid was the cause of all that crud in the pump and cylinders in the first place seeing it absorbs water.
zombie1969 is offline
post #18 of 27 (permalink) Old Jul 13th, 14, 1:49 AM Thread Starter
Originally Posted by MARTINSR View Post
The other very good thing that came from it was I changed it out to run automatic transmission fluid, I am MUCH happier with something that won’t eat any paint like aircraft paint stripper!
I said I used automatic transmission fluid in the original post of the thread. They originally used brake fluid.
Brian Martin
MARTINSR is offline
post #19 of 27 (permalink) Old Jul 14th, 14, 7:47 AM
AKA Zombietroll
I thought you had originally used break fluid. I saw where you changed over to atf. Was that actually used from the factory or did a prev owner do something stupid. It looks like it did a hell of a lot of damage considering my system is all original and works great knock on wood.
post #20 of 27 (permalink) Old Jul 14th, 14, 10:03 AM Thread Starter
I tried to use it with the brake fluid because that is what it used originally as I remember. I don't remember now but I think that is what I found in my study of it. I tried it, the pump didn't work, and that is when I pulled it apart as shown in this thread. I then after cleaning it up put the ATF.
But as I remember there wasn't much to think about, they used brake fluid, from what I remember when the car was new.
Brian Martin
MARTINSR is offline
post #21 of 27 (permalink) Old Aug 13th, 14, 1:12 PM
Schematic of 1964 - 1970 Chevelle conv. top pump.
70SS454 is offline
post #22 of 27 (permalink) Old Aug 14th, 14, 9:33 AM Thread Starter
Thumbs up Re: "Basics of Basics" top pump/motor disassembly and rebuild.
AWESOME great addition to this thread. I seem to have seen it before, is it in the regular body manual? I should have posted it if I have seen it, thanks for doing it.
Brian Martin
MARTINSR is offline
post #23 of 27 (permalink) Old Jan 6th, 16, 5:44 PM
Just wanted to say thanks, and to let you know this post is still helping us out!
oneblue396 is offline
post #24 of 27 (permalink) Old Jan 6th, 16, 6:23 PM Thread Starter
RIGHT ON!
MARTINSR is offline
post #25 of 27 (permalink) Old Apr 4th, 16, 5:36 PM
So in a nut shell, there is NO rebuilding the cylinders? Correct?
1964 Chevelle SS Convertible
msra4896 is offline
post #26 of 27 (permalink) Old Apr 5th, 16, 9:54 AM Thread Starter
It is certainly not impossible, I just don't see a good reason to jump into it personally. The replacement seems the way to go but you could give it a try.
joeyv69ragtop likes this.
MARTINSR is offline
post #27 of 27 (permalink) Old Apr 6th, 16, 7:07 PM
Thanks Brian. Jeff
msra4896 is offline
This Thread is more than 386 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
