Price Check on aisle 5, control arm bushings and seal... - Chevelle Tech
post #1 of 19 (permalink) Old Apr 14th, 04, 11:41 AM Thread Starter
Post
Ok, so my 70 started get this loud pop in the steering along with a noticable pang in the brake pedal and steering wheel.. when turning the car hard to either side... and when braking to a stop.. you let of the brake and kerpow.. on the drivers side..
also the thing was going through so much oil its retarded..
So, dropped it off at my local rip ya off, anf they pointed out quickly that the lower control arm bushing, driver front, was completely eat up, the whole job under there could be shifted with a bar.. also said the front harmonic seal was the source of the oil leak..
so.. with parts and labor, they want $817 to fix it all, that's all new upper and lower control arm bushings, both side, neo, and take weld something to something and fix the seal..
Good price or bad price?
70 Chevelle SS 454
plasma800 is offline
post #2 of 19 (permalink) Old Apr 14th, 04, 11:46 AM
Post
HOLY CRAPOLA! $817 dollars. wow. Are those polygraphite bushings or just rubber?
It is quite labor intensive to do the bushings, i once got charged $50 dollars to do that on both sides and an alignment. But that was under the table. I wouldn't pay any more then $400 for the whole thing, and i wouldn't pay that i would just do it myself.
Harmonic balancer is easy to get to, unsure of a seal from around there, but don't know a whole lot about motors.
gUmBaLL68Malibu is offline
post #3 of 19 (permalink) Old Apr 14th, 04, 11:58 AM
Hey You!
Post
"and take weld something to something and fix the seal.."
JB Weld?...run. I can't even see how that would work. The gasket set is around $16.00 and a balancer saver sleeve is around $5.00 to fix it right. There is some labor to involved to do it right. Price is way too high.
John_Muha is offline
post #4 of 19 (permalink) Old Apr 14th, 04, 12:02 PM Thread Starter
Post
Wow.. that sounds much better.. that does seem expensive in that light..
(tac weld) they want to weld the control arm to....... something.. im not sure what he's talking about..)
The said something about putting in the good bushings... Anyone have any reco's on bushings.. and please keep the comments coming.. cause i really have to watch my cash!! Im not into wasting money at the moment...
also keep in mind.. this is my daily driver right now, and I am hoping to get another car soon, so I can park this thing for the summer and work on it as i go...
Another guy i know just quoted me 5 and some change to do both, parts labor and tax..
post #5 of 19 (permalink) Old Apr 14th, 04, 1:39 PM
Mark
Post
Hold on a second here...
"take weld something to something" 1. doesn't mean JB weld (TACK WELD maybe?), and 2. tells me you don't know what's wrong.
Get a better grip on what's wrong and what they're doing to fix it and report back later.
Xtreme70SS396 is offline
post #6 of 19 (permalink) Old Apr 14th, 04, 1:42 PM Thread Starter
Post
Yeah, they were talking about tack welding the upper control arm to something
post #7 of 19 (permalink) Old Apr 14th, 04, 2:01 PM
Earl
Post
Maybe tack welding the control arm bushings to the control arms?
71chevelleconvtble is offline
post #8 of 19 (permalink) Old Apr 14th, 04, 2:12 PM
Post
Where are you in houston? I use to work at a place at 13716 hempstead hwy.B&B tire and brake.Call and get a price, if john still owns the shop he had great prices.
67-468 is offline
post #9 of 19 (permalink) Old Apr 14th, 04, 2:24 PM Thread Starter
Post
Im nw, kinda in that area...ill call!
thankSS!!!
post #10 of 19 (permalink) Old Apr 14th, 04, 2:37 PM Thread Starter
Post
Would this be an incredibly nasty job to take on yourself...?
post #11 of 19 (permalink) Old Apr 14th, 04, 2:43 PM
Post
The uppers are not to bad,the lowers are a tuff job without a lift.If you need springs now is the time to do them.
67-468 is offline
post #12 of 19 (permalink) Old Apr 14th, 04, 3:15 PM
Mark
Post
If they were looking at tack welding something, there may be a little damage that would make the job harder. www.p-s-t.com has a good instruction sheet on how to do all the bushings, it will give you a good idea of what you're up against.
Good luck either way!!
post #13 of 19 (permalink) Old Apr 14th, 04, 3:43 PM Thread Starter
Post
Thats the other thing im wondering about... if im gonna get it torn apart... what else should i look at doing?
Also, I told that shop flat out i had 550 bucks.. thats it, do it or dont.. we'll see what happens (actually, that is even more than i need to spend right not... but i can squeeze it i guess)
post #14 of 19 (permalink) Old Apr 14th, 04, 3:46 PM Thread Starter
Post
whats this kinda stuff going to do for me..
http://www.p-s-t.com/gm/gmfekpgs.html
post #15 of 19 (permalink) Old Apr 14th, 04, 4:27 PM
Hey You!
Post
I put in rubber bushings on my 64. If you are short on cash they do work. Use a chassis shop to press the old bushings and ball joint out and in for about $15.00 labor per arm.
To fix the left side and do the right side later it can be done for around.
$60.00 labor to press the bushings
$20.00 rubber bushings
$30.00 ball joints
Plus
$15.00 4-pound machinists hammer
$10.00 internal spring compreser.
Will need a small 4 wheel shop jack to raise up the arm.
If the lower arm is damaged enough where the lower bushings have to be welded in, I'd get another arm.
This Thread is more than 4820 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
