Front Spring Question - Chevelle Tech
post #1 of 2 (permalink) Old Apr 5th, 04, 12:41 AM Thread Starter
Post
I installed the new front springs today, and after I stepped back and looked at my work, I realized that one of the springs is not seated correctly, that is, the end of the coil is not lined up between the 2 holes in the lower control arm. Now, I understand this can creat a problem with the car sitting level, so my question is this: Is it possible to put the spring compressor on, and rotate that spring...without disconnecting the spindle? What do you guys think?
1971 SS 454 Project
hilks is offline
post #2 of 2 (permalink) Old Apr 5th, 04, 8:30 AM
Roger
Post
I'd give it a try. It's not to dangerous if you keep both ball joints bolted to the spindle. If it doesn't work, and you have already got the spring compressed, break a ball joint loose and seat it correctly. Be careful, we all know how much damage a wild coil can be.
Roger
67shovel is offline
This Thread is more than 4828 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
