wheel hop - Chevelle Tech
post #1 of 32 (permalink) Old Apr 12th, 04, 9:33 AM Thread Starter
Post
Can someone help me out here. what exactly causes wheel hop. (vs. just spinning and not hopping) I have alot of wheel hop on my 71. Will wider tires help this. I really don't want to get into traction bars, etc. because I want to keep a stock look. I did a search here and really didn't see this issue addressed at length. (which surprised me)
71 SS 454 M22,
71 SS 454 M22 project car
68 Barracuda fastback 340 727
Newest addition 68 Coronet R/T Convertible
68 R/T Vert
Pair of 71's
Photo Album
A.C.E.S. #6015 CanAm #127
The stable
freshayr is offline
post #2 of 32 (permalink) Old Apr 12th, 04, 9:46 AM
william
Post
if you don't want to get into traction bars and such. put a good set of rear shocks on the car such as monroe sensatrac. then install solid alumiunum bushings in the lower rear control arms, they will have grease zerks for lubing the pivot. this is how my 68 is set up with a 4:10 gearing 12 bolt posi, there may be other suggestions.
fast as fast can be!!!
1966 chevelle malibu454 4 speed
1968 chevelle malibu 454 th400
1981 firebird formula
bradford is offline
post #3 of 32 (permalink) Old Apr 12th, 04, 10:04 AM
Gregg
Post
One of the most common causes for wheel hop is a car with a raised suspension (tall springs in the rear) or sloppy bushings in the rear trailing arms. Any combo of these conditions may start wheel hop. A cure, which is easy to do, can be found in the installation of Lakewood or Edelbrock "No-hop" bars. These are not like the "ladder bars" of years ago. Ladder bars will result in a harsh ride, but do cure the wheel hop. No-Hop bars install on the rear axle housing and re-locate the upper, rear control arm mounting point in a position that is higher & forward from stock. This results in moving your pinion angle upward, changing the instant center of your car. They're easily installed and are not visible unless you're laying on the ground. I installed a set of Edelbrock's on my '72 SS and all wheel hop went away. Traction is another story....
Gregg Haskin
'72 Chevelle W-code SS454 Coupe w/ZZ502
'72 Chevelle SS Convertible - Straub-Foxwell built Vortec 355
'71 Pro Touring Chevelle - Straub-Foxwell built 542, 739HP/720TQ
'71 Chevelle MULE Drag Car - Straub-Foxwell built 509, 710HP/680 TQ
'72 El Camino numbers-matching W-code SS454
TEAM CHEVELLE #726
ACES #4486 Forever!
CAN-AM Chevelles Member
Best: 1/4 Mile: 11.14 @ 120MPH
www.72ChevelleSS.com
www.71ProTouringChevelle.com
riskyvt is offline
post #4 of 32 (permalink) Old Apr 12th, 04, 10:21 AM
Post
We had exactly the same problem as you did with our 71. We ordered AC Delco shocks through Ground Up and all new rear bushings (the stock rubber ones) and new upper control arms (all gotten through Ground Up)and new springs, which corrected the pinion angle (which is a cause of wheel hop) and helped with the weight transfer.
Rigt after that was done, she hooked like she has never hooked before . All wheel hop was gone, and she just squatted and ran.
Hope this helps, and good luck with your ride.
'71 SS454 - Canadian Built
468" BBC, M-21, 3.55 12-bolt posi
"Real Race Cars Have a Clutch..."
Big Red Roastin' Em (Video)
The Body
The Soul
Other Project - 66 Cobra - 475"BBC
RedSS454 is offline
post #5 of 32 (permalink) Old Apr 12th, 04, 10:28 AM Thread Starter
Post
Oh baby, now you are making the hair on the back of my neck stand up! [img]smile.gif[/img]
What exactly is the pinion angle. I assume that has to do with the angle that the driveshaft comes into the rear?????
71 SS 454 M22,
68 R/T Vert
Pair of 71's
Photo Album
The stable
freshayr is offline
post #6 of 32 (permalink) Old Apr 12th, 04, 11:09 AM
Post
My 70SS also developed wheel hop. I rebuilt the rearend with polly bushings, stock springs etc. No more wheel hop.
This is a street driven car with standard size tires
Bill Taylor
TC Member #73
Feature Car December 99
My Showroom
Bill T SS70 is offline
post #7 of 32 (permalink) Old Apr 12th, 04, 11:14 AM
Post
Do you have air shocks? I've found that if my shocks are too high (too much air in them) I wheel hop like crazy. but... When the car sits level or only a little higher in the rear the wheel hop turns into a nice smooth spin. Also helps traction
Andrew McMullen
"Marilyn" is my 68 Chevelle SS 396
"Live by ethics, not by rules."
"Live Simply, so that others can simply live"
marilynSS396 is offline
post #8 of 32 (permalink) Old Apr 12th, 04, 11:21 AM Thread Starter
Post
yes I have air shocks.....they are very old and probably could stand to be replaced.
71 SS 454 M22,
68 R/T Vert
Pair of 71's
Photo Album
The stable
freshayr is offline
post #9 of 32 (permalink) Old Apr 12th, 04, 11:32 AM
Post
I installed Southside Machine bars (Jeg's sells them now) on my 4 speed 70 SS396 and they cured my wheelhop problems.Factory swaybar hooked right up,and they looked very,very stealth.Just an FYI,my car had stock springs,Monroe shocks and newer rubber bushings before the SSM bars,and I had violent wheelhop.
mr 4 speed is offline
post #10 of 32 (permalink) Old Apr 12th, 04, 11:45 AM Thread Starter
Post
do you have a part number for them??? I tried a Jegs search for SSM bars, etc. and couldn't find them. thanks
71 SS 454 M22,
68 R/T Vert
Pair of 71's
Photo Album
The stable
freshayr is offline
post #12 of 32 (permalink) Old Apr 12th, 04, 12:49 PM
Post
</font><blockquote>quote:</font><hr />Originally posted by RedSS454:
</font>[/QUOTE]You got it. The pinion angle is the angle in which the driveshaft runs into the rear. If it is too high (as ours was because we had wagon/elco springs from a previous owner )the angle is off, and causes wheel hop. With air shocks, this is usually the case. Does your rear sit higher or lower than a stock chevelle appears? Than this might be your problem. Try and replace them with normal shocks and and stock springs, and you might be able to solve your problem, at the same time giving you a nice smooth ride [img]smile.gif[/img] .
Good Luck [img]graemlins/thumbsup.gif[/img]
The Body
The Soul
RedSS454 is offline
post #13 of 32 (permalink) Old Apr 12th, 04, 1:07 PM
Post
My 65 ragtop would hop so bad, I spun the axle shaft an 1/8 of a turn in the housing. I opted to install a set of ladder bars, never looked back. Really nice addition to the 4/11 posi... [img]graemlins/thumbsup.gif[/img]
No, he didn't slam into you, he didn't bump you, he didn't nudge you, he "rubbed" you. And rubbing, son, is racing.
SteveW is offline
post #14 of 32 (permalink) Old Apr 12th, 04, 1:09 PM
Post
My pinion angle is set at -4deg. Which BTW is also a good starting point.No hopping ,just putting the wheels right were they should be
MY VELLE
Steeev
66 Chevelle /383/TH350/4:10
60ft 1.55
1/4 11:51
mph 117.26
"I'm Not Driving Fast Honey"....
"You Wanna See Fast"...........
[urhttp://i27.photobucket.com/albums/c171/onebadd66/IMG_0189.jpgl=http://
onebadd66 is offline
post #15 of 32 (permalink) Old Apr 12th, 04, 1:20 PM
Post
Onebad66 (Steve), I like the picture of your '66. I see you have it listed as a 383. If I wanted my wheels in the air too ( ), could I accomplish with about $3,500...or at least build a decent street machine. And would you stick with a stroker?
SteveW is offline
You may not post new threads
You may not post replies
