body bushings - Chevelle Tech
post #1 of 4 (permalink) Old Apr 5th, 04, 1:51 AM Thread Starter
Timothy
Post
I'm going to be taking the body of my '72 Malibu off the frame so I can have the frame powdercoated, and thought it would be a good time to replace the old body/frame mount bushings. What do you guys suggest going with, just a stock replacement or some of the new polyurethane ones? Do the poly ones feel any different than stock?
I prefer silent vice to ostentatious virtue.
'01 Suzuki GSX-R1000 - 12.18 @ 122.63 5/19/2006 (uncorrected at 4,600')
'05 Dodge Magnum R/T
'94 Corvette LT1 (only 68K miles)
'72 Chevelle Malibu (under construction. still.)
three85stroker is offline
post #2 of 4 (permalink) Old Apr 5th, 04, 11:41 AM
Rad
Send a message via AIM to Rad
Post
the stock rubber gives you a softer ride. while the new poly will b a little rougher but the car will handle slightly beter. i heard of people mixing them up a little. hard out back and soft up front or vice versa to improve handling but still retain a somewhat good ride. not sure which way they did it.. ... myself im going with stock rubber mounts for my 67 4 door velle..
Rad is offline
post #3 of 4 (permalink) Old Apr 5th, 04, 1:42 PM Thread Starter
Timothy
Post
Anyone else have any experience with the poly bushings? The car is going to be about 70% street driven, but even on the street it will still be driven moderately aggressive.
post #4 of 4 (permalink) Old Apr 5th, 04, 2:27 PM
Post
I replaced mine with stock type, and then changed to poly.
The ride was a little firmer, but not that much. I could not see anybody thinking they were too stiff, even for someone only interested in a smooth ride.
Mine is daily driven and would highly recommend the polys to anyone.
Charles Perrell
cperrell@yahoo.com
65 malibu SS Convertible
283 4bbl & 2004r
cperrell is offline
You may not post new threads
You may not post replies
