Correct Heads 1972 L65 - Chevelle Tech
post #1 of 4 (permalink) Old Jul 15th, 05, 10:00 PM Thread Starter
Bryan
Question Correct Heads 1972 L65
Hey guys, I just pulled the valve covers off of my 1972 El Camino. The engine is the stock numbers matching 350cu 165hp 2bbl (RPO L65). The head numbers are 3986339X. The casting dates are correct for my motor.
I'm the second owner of this car and bought it as a low milage (67,000 miler) in 1997.
I checked Colvin's book (Chevrolet by the Numbers) and he lists these heads as being 1971 used on 307cu engine installed in Novas, Chevelles, and Camaros as well as on 350cu 270hp (low compression) engine in full size cars. The book lists these heads as having 1.72/1.5" valves and 74.56cc chambers.
My question is there any other documented 1972 L65 engines found with these heads? What heads are usually found on L65 engines?
Bryan W. Shook - Redefining Automotive Law
Favorite Quote: Some people have shrinks. Some people have their garage.
elcamino72 is offline
post #2 of 4 (permalink) Old Jul 16th, 05, 12:35 AM
JohnH
Re: Correct Heads 1972 L65
Had the same engine in my 72 Chevelle. All original. Head # 3998993 Mortec shows these as 3998993....72-73...307/350......75cc chambers
John H.
TC # 2539
72 Malibu 454-4spd-3:73 posi
Soon to be 502-5spd
2014 GMC Sierra SLT
My Website
Picture of My Car
454Malibu is offline
post #3 of 4 (permalink) Old Jul 16th, 05, 7:57 AM Thread Starter
Bryan
Sorry, these numbers are very hard to read, after looking again, I have determined that the number on the heads is actually 3988336X.
Okay, this number is not in Colvin's book, does anyone know the valve size of these heads?
post #4 of 4 (permalink) Old Jul 17th, 05, 12:53 PM
Cam
Cameron Milne
I don't know the casting numbers so I can't help there, but all stock 307s used 1.72 / 1.50 valves while the L65 & L48 used 1.94 / 1.50 valves. 400s used 1.94 / 1.60 valves and the LT-1 uses 2.02 / 1.60s.
Cam is offline
This Thread is more than 4363 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Z16 Heads.. I missed buying them:( Len 1999 -- 6 Nov 24th, 07 5:26 PM
sbc heads...what's the differences tm53chev Engine 5 Feb 20th, 05 9:45 PM
Correct 1972 Tan Interior EkS Restoration Corner 6 Sep 22nd, 04 9:06 AM
Correct Plugs for 041 SB Heads?? - Help ss396Jeff Engine 1 Aug 7th, 04 8:39 AM
spark plugs for big block semi closed heads? stevenb8 1999 -- 6 Dec 23rd, 99 8:54 PM
