Correct intake/air cleaner, '69 SS? - Chevelle Tech
post #1 of 6 (permalink) Old Apr 20th, 17, 9:29 AM Thread Starter
What is the correct air cleaner and intake manifold for a big block 69 Chevelle? One that fits under the hood.
twalker is offline
post #2 of 6 (permalink) Old Apr 20th, 17, 10:22 AM
Keith
Re: Correct parts
What engine horse power configuration do you have or want to have?
1994 Corvette coupe LT1 auto
Maryland Chevelle Club #682
keithb is offline
post #3 of 6 (permalink) Old Apr 21st, 17, 12:11 AM Thread Starter
Re: Correct intake/air cleaner, '69 SS?
The horsepower is around 440, with an aluminum heads, ZZ454 crate motor. Previous owner installed a Edelbrock carb, and a standard looking 3 inch air cleaner. He then proceeded to cut a hole in the inner hood so it wood fit. :-(
I think part of the problem is the base of the air cleaner isn't as deep as it could be, but not sure about that. I would like to get the correct parts, then replace the hood.
twalker is offline
post #4 of 6 (permalink) Old Apr 21st, 17, 12:15 AM
David
Are you looking to go back to the factory cast iron intake?
55 210 Chevrolet New project
64 El Camino (sold to finance new project)
67 SS Chevelle '396
69 Sanger Flat Bottom boat
77 El Camino parked daily driver
78 Z/28 Camaro, High School Car Class of 80 350'
80 Spectra 21' Mini Day cruiser Blown 454
88 IROC Camaro (sold to finance new project)
1994 fac2 dr Blazer 4x4
02 F-250 7.3L Diesel 4" lift
david_396 is offline
post #5 of 6 (permalink) Old Apr 21st, 17, 5:41 AM
von
Lifetime Founding Member
Von
Buy a repro open element air cleaner from a Chevelle parts vendor like NPD. It comes with the proper drop base and factory appearing chrome lid.
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
von is online now
post #6 of 6 (permalink) Old Apr 22nd, 17, 10:40 AM
Ole
If you are looking for what came as stock equipment on 1969 SS 396 cars, 325 and 350 HP 396 versions came with medium rise, cast iron, oval port intakes and Quadrajet carburetors, while the 375 HP version was fitted a with square bore (Holley carb) aluminum intake that had large rectangular ports. If I recall correctly the 325 HP engine came with an enclosed element air cleaner with a long snout. This air cleaner was painted black. The 350 and 375 HP engines came with an open element air cleaner with a chrome cover. The bases were not the same, however, as the top of the Q-Jet and Holley carbs were different.
Saltherring is offline
