67 blinker tach wiring - Chevelle Tech
post #1 of 5 (permalink) Old Mar 14th, 05, 4:28 PM Thread Starter
guys,is there a plug connecter on a 67 with a blinker tach for the blinker in the tach? Im sure there is, but does it come off the dash right blinker indicator wire?also will the blinker tach work with a mallory tach adapter,needed the adapter for the old sun super tach would work with the mallory 6a box--just askin--67rat
67RAT is offline
post #2 of 5 (permalink) Old Mar 14th, 05, 6:46 PM Thread Starter
Re: 67 blinker tach wiring
I mean the left blinker lead!!!!!
In other words where does the blinker lead in the tach hook up to the blinker lead in the car?--67rat
the edit time limit is to short here!!!!
67RAT is offline
post #3 of 5 (permalink) Old Mar 14th, 05, 8:47 PM
Dale
According to the AIM (and assuming the blinker lead is the light blue wire in the tach harness?)
It appears as though the blue lead from the tach harness splices into the existing directional signal connector and standard harness wire is probably taped up. I have drawing from the AIM if you'd like me to send it to you. Just give me an address.
DaleM is offline
post #4 of 5 (permalink) Old Mar 14th, 05, 11:22 PM
The gauge dash harness left blinker wire has a connector in the wire that allows the removal of the light so that the tach blinker lead can be attached. Here's a pic.
TC member 368
Elree Colby is offline
post #5 of 5 (permalink) Old Mar 15th, 05, 4:18 PM Thread Starter
ok dale and elree,I will check it out and see how mine is,didnt look yet ,I will wait till instal--thanks guys--67rat
67RAT is offline
This Thread is more than 4423 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
