71 HD Battery Question - Chevelle Tech
post #1 of 6 (permalink) Old Sep 27th, 03, 7:50 PM Thread Starter
Post
I have a 71 SS 454 that came with the Heavy Duty Battery option. Did this original battery have top posts or side posts? Thanks for any help.
Mike Martin
SS454MIKE is offline
post #2 of 6 (permalink) Old Sep 27th, 03, 9:00 PM
Bill Rose is offline
post #3 of 6 (permalink) Old Sep 28th, 03, 6:56 AM
Post
The original batteries were also smooth on the top surface, not a grainy texture.
--Jim
MY LS5 is offline
post #4 of 6 (permalink) Old Sep 28th, 03, 12:00 PM Thread Starter
Post
Where would you recommend getting a replacement, period type battery from? Thanks for the responses.
post #5 of 6 (permalink) Old Sep 29th, 03, 5:49 AM
Post
New Castle
Antique Auto Battery
Here's a couple Mike. Tell them what engine you have and remember about the top surface texture. You can also buy an original GM 1971 date coded battery at some swap meets but they're $$$
Good Luck.
--Jim
MY LS5 is offline
post #6 of 6 (permalink) Old Sep 29th, 03, 6:47 AM
Albert
Post
Carefull with the replacement (reproduction) batteries. Not to vendor bash but they don't last. I have bought four in the last four years..for different cars and none of them has lasted more than two years...some not even one!. I started using the new GM maintenece free batteries...6 year warranty and have had no problems. If looks are important you could swap in a repro battery for shows and then use the other for everyday or weekend use...ALbert
1969 9566AA COPO Chevelle
COPO 2
COPO motor
1969 Malibu 489 ZL-1 T 56
http://i518.photobucket.com/albums/u...DSC_0201-1.jpg
1969 Beaumont 454 ZL-1 6 spd..under construction
http://i518.photobucket.com/albums/u...DSC_0520-1.jpg
1969 300 2 door post 427 ZL-1 4 spd
http://i518.photobucket.com/albums/u...DSC_0055-1.jpg
1970 Olds W 30 2 door post
MCC#511 ACES #1805
alss is offline
This Thread is more than 5016 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
