1970 fuel sending unit wire? - Chevelle Tech
post #1 of 15 (permalink) Old Dec 25th, 12, 11:03 PM Thread Starter
Jason
Can anyone tell me where the fuel sending unit wire that attaches to the sending unit at the gas tank runs to? I need to know if it runs to the back of the car and ties into the rear tail light harness on the driver's side or where at? If someone has a picture, that would help also.
Thanks in advance!
jp68camaross is offline
post #2 of 15 (permalink) Old Dec 25th, 12, 11:22 PM
Re: 1970 fuel sending unit wire?
It plugs into the harness in the trunk on the driver's side and that wire loom runs under the floor mats to near the fuse block.
post #3 of 15 (permalink) Old Dec 26th, 12, 2:20 AM
Donny
Thanks in advance!
Actually,iIt depends on the car. On a 70, it is a tan extension wire that comes off the sending unit and plugs into the main rear body harness in the trunk.
Donny
aawtech is offline
post #4 of 15 (permalink) Old Dec 26th, 12, 12:07 PM Thread Starter
Jason
I have the tan wire coming off the sending unit, but didn't know where to run it for now and I am getting ready to put the gas tank up in the car, as I don't have any of the other wires in the car anywhere, and someone else took the car apart! So does it need to run over towards the driver's rear taillight and up thru the big hole in the rear taillight area?
Thanks for the help!
post #5 of 15 (permalink) Old Dec 26th, 12, 12:22 PM
hmm, as I recall, it comes up through a hole near the trunk latch.
post #6 of 15 (permalink) Old Dec 26th, 12, 1:26 PM
Donny
You are correct! That is where it plugs into the ear body harness.
Donny
aawtech is offline
post #7 of 15 (permalink) Old Dec 26th, 12, 1:35 PM
Run it through the hole on the driver side with the brake/tail lights. The right rear marker light wires run through the hole on the other side by the trunk latch
67 Chevelle convertible Ly6 4l80e
68 Nomad Custom Wagon
70 Chevelle Convertible
71 SS 454 Chevelle LS5 W/Build Sheet
72 Chevelle Convertible RJ 502 TKO 600
73 El Camino SS
68 Buick Skylark LQ9 4L65E
72 buick GS 350
http://www.chevelles.com/showroom/data/500/P4190076.JPG
http://www.chevelles.com/showroom/da...m/P1010112.JPG
hbcruiser is offline
post #8 of 15 (permalink) Old Dec 26th, 12, 3:32 PM
Gregg
My 70 has a plug connector behind the rear bumper, driver/left side accessible from the underside of car or through the license plate opening. And the other end connect to the sending unit on the tank.
Gregg
69 Malibu SS drive train
70 SS Chevelle LS5
gzwhite is offline
post #9 of 15 (permalink) Old Dec 26th, 12, 6:46 PM
Ray
This what the tan wire connects into in the rear wiring harness
70 SS Chevelle Van Nuys Cal Built
http://s777.photobucket.com/albums/y...70%20chevelle/
Chevelle and El Camino Club of Oregon
http://www.chevelles-oregon.com/home/
shadowgray396 is offline
post #10 of 15 (permalink) Old Dec 26th, 12, 7:51 PM
Gregg
Ray - that's the hookup location.
Is that your car before the restore, or was that the car prior to the SG?
Gregg
70 SS Chevelle LS5
gzwhite is offline
post #11 of 15 (permalink) Old Dec 27th, 12, 12:52 AM
Ray
That's correct. If I reading his post he was wondering where the wire went to.
The car in the picture is the first car I purchased also a shadowgray paint coded car but and got screwed on it, it was a 6 cylinder vin car even though it was advertized as an SS car. Had I found TC before I started looking I would have been better educated. It became a parts car.
post #12 of 15 (permalink) Old Dec 27th, 12, 1:06 AM Thread Starter
Jason
The picture and description helps! I have a round looking push plug (looks like a rubber grommet) on the end of the tan wire and wasn't sure where it pushed thru, the body or the frame.
Thanks to all who answered!
post #13 of 15 (permalink) Old Dec 27th, 12, 5:28 PM
Gregg
JP glad you got it worked out.
Ray - we all ahve those times that we get schnookerd, at least you made the most of a bad situation!
Gregg
70 SS Chevelle LS5
gzwhite is offline
post #14 of 15 (permalink) Old Dec 28th, 12, 11:07 AM
Lance
Routing of sending unit wire on top of a '70 fuel tank.
ACES #08588
1970 Chevelle SS
1970 Olds 442 Survivor
1997 SVT Cobra Convertible
smoke' em II is offline
post #15 of 15 (permalink) Old Dec 28th, 12, 5:34 PM
Gregg
Lance, thanks for the pic - it helps me as the tank will go in this weekend if all goes well. Nice to see the wire routing etc.
Gregg
70 SS Chevelle LS5
gzwhite is offline
This Thread is more than 1580 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
