1966 guages / speedometer lens question - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old May 6th, 12, 7:38 AM
Bryan
Re: 1966 guages / speedometer lens question
Yep---aware of that----but I updated my brakes, and then used 67 indicator lamps
oil, alt, brake, temp along with the gauges.
So, I needed the high beam in the speedo.
Besides--just tossed that info out in the event one needs to replace his
speedometer on a 67 with indicators.
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
Bryan59EC is offline
post #17 of 20 (permalink) Old May 9th, 12, 1:31 AM Thread Starter
steve
and the brake indicator is where for a 66 and where for a 67??
64tempestwagon is offline
post #18 of 20 (permalink) Old May 9th, 12, 7:31 AM
Dale
Depends if you're talking factory gauge or warning lamps dash.
1966 factory non-gauge dash with warning lamps - no BRAKE warning lamp.
1967 factory non-gauge dash with warning lamps - BRAKE warning lamp now standard.
1966 & 1967 factory gauge dash. BRAKE added to 66 and moved for 67 to rightmost lamp pod. Also note BRIGHT moved to leftmost lamp pod.
Ref: 1966 & 1967 Chevelle Reference CD(s)
http://chevellecd.net
DaleM is offline
post #19 of 20 (permalink) Old May 10th, 12, 1:28 AM Thread Starter
steve
Wow thanks...any way of finding correct "brake" and "bright' lenses in other 66 chevy models and then adapting to non guage clusters for tthe correct look with gauges (aftermarket Shiftworks guages)
post #20 of 20 (permalink) Old May 10th, 12, 10:28 AM
Dale
I think they're being made in the aftermarket now. I seem to remember talkin gwith someone who did a warning lamp to gauge conversion and needing the BRIGHT and BRAKE lenses but can't remember now who had them made.
DaleM is offline
