Could these exhaust manifolds be from a numbers matching car - Chevelle Tech
post #1 of 6 (permalink) Old Mar 20th, 12, 9:05 PM Thread Starter
Hi everyone, i've purchased a 70 chevelle ss that is to be numbers matching. I'm currently tearing it down to get the engine rebuild (the vin in stamped in the front pad) car had 1 repaint and all signs show its original or looks like it. The manufacture date is june 1970 but when pulling the exhaust manifolds they are dated E6 70 (left) and D21 70 (right) would it be normal for the exhaust manifolds to have diff. dates..... 2nd part is could the heads also then have different dates?
Jason1 is offline
post #2 of 6 (permalink) Old Mar 20th, 12, 9:10 PM
Keith
Re: Could these exhaust manifolds be from a numbers matching car
Yes the line workers pulled parts from a big bin. They only cared if it was the correct part for the job.
1994 Corvette coupe LT1 auto
Maryland Chevelle Club #682
keithb is offline
post #3 of 6 (permalink) Old Mar 21st, 12, 3:19 AM
Bruce
Is that the Assembly Date for the car or the engine? The engine's front pad is stamped with the exact Assembly Date. Obviously the original manifolds couldn't have been cast after the engine assembly date... I'd say 16 days would be a byte much on a small block (since so many were built), they may be okay for a Big Block.
"CQQL" my Nickey Chicago 1969 Chevelle COPO Tribute: http://s1012.beta.photobucket.com/us...88981229984076
Our You Tube Vids: http://www.youtube.com/user/NickeyCh...ow=grid&view=0
NickeyChevelle is offline
post #4 of 6 (permalink) Old Mar 21st, 12, 9:55 AM
leo
the engine was assembled at the Tonawanda plant and I am pretty sure it had the manifolds installed there, then painted. JMHO.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
www.mdchevelleclub.com
LeoP is offline
post #5 of 6 (permalink) Old Mar 21st, 12, 6:27 PM Thread Starter
Thanks for the responses, its an oshawa built car....would this also apply towards the heads? i had pulled the covers off a bit a go can't recall the exact dates but they were not the same date... i will be checking dates to make sure and will post.
Jason1 is offline
post #6 of 6 (permalink) Old Mar 24th, 12, 5:44 PM
Verle
Yes, heads are usually different dates. Workers had no interest/incentive to do anything like that. They just used the next available parts.
Exhaust manifolds were installed at the engine plant and were painted when the engine was painted. The paint quickly burned off when the engine was run a little while.
Verle
Tulsa, Ok
http://i877.photobucket.com/albums/a...e6June2010.jpg
Verle is offline
This Thread is more than 1921 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
