70-72 chevelle and monte carlo frames - Chevelle Tech
post #1 of 5 (permalink) Old Oct 27th, 11, 9:52 AM Thread Starter
dave
i want to use an entire 71 monte carlo firewall/cowl section and the frame as a temporary jig to rebuild a 70 chevelle convertible until i can find a nice convertible frame to transfer everything over to. i notice the monte carlo also has the two sets of firewall brackets that the body bushings bolt to,like the convertible.
i know the frame on a 70-72 monte carlo is longer than the chevelle from the firewall forward,but is it the same from the firewall back? the floorpans look to be the same. i know the trunk pans have a different design,but i think the body bushing locations are the same from the firewall back. can anyone verify this?
thanks, dave
re-animated is offline
post #2 of 5 (permalink) Old Oct 27th, 11, 10:53 AM
Joe Vega
Re: 70-72 chevelle and monte carlo frames
Yes......who gave away my secret. The Monte was considered a Heavy Duty application body, just like the convertibles, El Camino and Station wagon.
azchevs is offline
post #3 of 5 (permalink) Old Oct 27th, 11, 11:10 AM
Doesn't the Monte Carlo have a longer wheel base ??? 112" for the convert and 116" for the Monte.
fasteddies68 is offline
post #4 of 5 (permalink) Old Oct 27th, 11, 12:23 PM
The wheel base is longer. The frame is different from the cowl forward. The monte uses a different clutch cross shaft bracket because of it. To answer the O.P. question, the frame is the same as a hardtop from the cowl back. It is not boxed like a vert is.
RichG is offline
post #5 of 5 (permalink) Old Oct 27th, 11, 2:12 PM
Anakin
Now we know where you are getting all of the "convertible" font body mount boxes from.......
lrdvdr41 is offline
This Thread is more than 2011 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
