69 muncie 4 speed shifter bench vs. console - Chevelle Tech
post #1 of 15 (permalink) Old Oct 13th, 11, 11:27 PM Thread Starter
Casey
I picked up a claimed to be original muncie 4 speed console shift, shifter....the guy i got it from says its for consoles who is very knowledgeable, and a guy i work with who is also very knowledgeable says its a 4 speed bench seat shifter...i will post a picture tomorrow when i pick it up, if you guys could possibly post pictures of a bench seat shifter in a car and the same with the 4 speed console shifter id really appreciate it. Thanks Casey
Casey
2007.5 Duramax
1979 Camaro Arrival blue
Currently Chevelle-less
Caseys69 is offline
post #2 of 15 (permalink) Old Oct 14th, 11, 9:00 AM
mark
Re: 69 muncie 4 speed shifter bench vs. console
bench seat is a hook/ semi circle...console is straght half way up is is bent at a 45 and points to the driver....night and day differences......
marxjunk is offline
post #3 of 15 (permalink) Old Oct 14th, 11, 11:23 AM
Rob
Heres some pictures of my bench seat four speed non console.
http://www.1969supersport.com/hump.html
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
rubadub is offline
post #4 of 15 (permalink) Old Oct 14th, 11, 11:26 AM
Rob
And on my website with the chassis pictures numbers 1 through 63 http://www.1969supersport.com you will see some pictures of the four speed that came with it that fit and worked good before the frame off, so its not the original 4 speed that came in the car when it was new.
Rob
rubadub is offline
post #5 of 15 (permalink) Old Oct 14th, 11, 7:27 PM Thread Starter
Casey
this is the one i got, it is the "2 piece" ball type.....said to be an original pulled out of a 69 chevelle back in the late 70's
Casey
2007.5 Duramax
Caseys69 is offline
post #6 of 15 (permalink) Old Oct 14th, 11, 7:39 PM
Don
Some good references noted above. Although I can't really confirm it from my knowledge, there might have been a third different shifter handle used on a bucket seat "no" console car.
WEBSITE
Specialized Chevrolet Decals
Don_Lightfoot is offline
post #7 of 15 (permalink) Old Oct 14th, 11, 7:46 PM
Yes, there was a third shift handle for a bucket seat car with no console.
RealRed70 is offline
post #8 of 15 (permalink) Old Oct 14th, 11, 9:17 PM Thread Starter
Casey
that was my other concern, ive looked around but i cant tell. im personally 90% sure its not a bench shifter, but i have no idea if its a console or no console one.....
Casey
2007.5 Duramax
Caseys69 is offline
post #9 of 15 (permalink) Old Oct 14th, 11, 9:29 PM
Keith
Definitely not a bench seat shift handle. The bench seat handle curves up and over the seat for clearance when short guys like me have the seat all the way forward.
Keith Tedford is offline
post #10 of 15 (permalink) Old Oct 14th, 11, 9:49 PM
It is not a bench shift handle as stated above.
post #11 of 15 (permalink) Old Oct 14th, 11, 10:39 PM
You almost need a picture the console shifter and buckets non console shifter side by side to tell the difference. I do not have a picture. I thought I saw one on here in the forums a while back. Do a search.
post #12 of 15 (permalink) Old Oct 15th, 11, 12:04 AM Thread Starter
Casey
as long as this thing doesnt stick up too far or anything like that im fine with it, i just wanted to make sure it wasent gonna look stupid, but from the info ive gathered the floor shift and console shifter handles are very very similar
Casey
2007.5 Duramax
Caseys69 is offline
post #13 of 15 (permalink) Old Oct 15th, 11, 5:35 AM
Here's a comparison pic showing the difference between the "buckets/no console" (the upper 2), and the "with console" (the lower 1).
69 Chevelle SS396 L78 4-speed, Post Sedan, Black W/black vinyl bench seat. (Under restoration)
69 Chevelle SS396 L78 4-speed Post Sedan, Silver, black vinyl bench seat. Berger car
70 Chevelle SS454 LS6, M22, 4.10, Forest Green, Green buckets. (Nearing completion)
69 Chevelle SS 396 L35 Post Sedan, Silver, Blue bench, 4-spd (Sold)
RixLS6 is offline
post #14 of 15 (permalink) Old Oct 15th, 11, 10:30 AM Thread Starter
Casey
mine definitely seems to look more like the lower one, thanks alot for the picture!!
Casey
2007.5 Duramax
Caseys69 is offline
post #15 of 15 (permalink) Old Oct 15th, 11, 5:31 PM
Sure, glad to help.
RixLS6 is offline
This Thread is more than 2023 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
