1970 Heater Control Valve vacuum hose routing - Chevelle Tech
post #1 of 5 (permalink) Old Nov 7th, 10, 9:33 PM Thread Starter
Rob
Does anyone have a photo of how the vacuum line runs to the heater control valve on a 70' Chevelle? I'm in the process of installing mine. I have the original vacuum line on the car and I'm not 100% sure how it gets around the evaporator core to the valve. The vacuum pod inlet points to the front of the car... right?
Thanks,
Rob.
Mr. Chevrolet is offline
post #2 of 5 (permalink) Old Nov 7th, 10, 10:31 PM
Charlie
Re: 1970 Heater Control Valve vacuum hose routing
If I'm not mistaken, there is a rubber boot that goes thru the firewall up near the cowl, with a hose in the middle of it,that runs to the heater control manifold.
vetteman_72 is offline
post #3 of 5 (permalink) Old Nov 9th, 10, 12:19 AM
It comes out of the firewall via the grommet that has the main vacuum line coming inside the car from the vacuum resovoir tank mounted on the a/c "suitcase".
It is then strapped to the electrical harness that feeds the blower motor/fan resistors etc.
I have the general aftermarket hotwater shut-off valve on mine, but other than this, I reconnected everything factory (except I didn't use the lousy tower clamps on my hose connections!).
See the pic of mine.
Coppertop is offline
post #4 of 5 (permalink) Old Nov 9th, 10, 8:34 PM Thread Starter
Rob
Thanks for the help guys, much appreciated.
Rob.
post #5 of 5 (permalink) Old Nov 12th, 10, 12:40 PM
On my 70 the Vac. hose heads down near the bottom of the suitcase, Near the bottom of the suitcase mine has a 1/4" wide loop that is attached to the suitcase, This Fac. loop pushes into a pre-made hole in the suitcase. This keeps the Vac. hose away from the exhaust.
The water valve is attached to the inner fender with 3/16" pop rivits.
Robinls5 is online now
