67 Chevelle SS/396 grill emblem - Chevelle Tech
post #1 of 14 (permalink) Old Dec 29th, 09, 1:24 PM Thread Starter
jason
I have what I think is an original 1967 SS/396 grill emblem that was on my car when I bought it. It was in good shape so I gave it some new paint and when I bolted it up to the grill it kind of sticks out from the grill about 1/2 of an inch? Is this correct. The backing bracket looks like the one I see in the catalogs with the reproduction emblem. Does the SS emblem itself have 2 square pieces with studs attached that rest up against the grill? It just don't look correct to me and it is hard to look at pictures on the internet. I even tried to search on the site for a picture of an emblem but had no luck.
Jason
Jason 67 conv is offline
post #2 of 14 (permalink) Old Dec 29th, 09, 3:45 PM
Re: 67 Chevelle SS/396 grill emblem
sounds correct to me. pictures in the standard catalog of chevelles all look to stick out a bit from the grille.
huffhuff is offline
post #3 of 14 (permalink) Old Dec 29th, 09, 5:42 PM
Herbie
The bottom of the emblem should stick out more. There is a bracket behind the SS emblem but I don't remember exactly what it looks like. It causes the bottom to stick out more and the emblem to me more plumb.
I will look at mine when I get home and let you know if someone else has not.
http://www.chevelles.com/forums/pict...&pictureid=490
Herbie
'67 SS Chevelle 460"
XE284, 9.97:1, CK 2004R, 3.42 12bolt
Holley 770SA, RPM AirGap, 3200 stall
hpsherlin is offline
post #4 of 14 (permalink) Old Dec 29th, 09, 11:55 PM
Herbie
The bracket is attached to the emblem with two studs that stick thru the grill.
Engine side of the grill has a upside down U shaped bracket that attaches to the emblem studs.
Hope this helps
Herbie
post #5 of 14 (permalink) Old Dec 30th, 09, 12:26 AM
The top of the emblem lays almost against the grille. The bottom sticks out. Looking at it from the side the emblem should be verticle. Here's a pic: http://www.itsawarzone.com/gallery/v..._1038.JPG.html
The top of the two square sections of the bracket on the back of the emblem go into the wide opening in the center of the grille, and slide up against the thin grille bar right above the center opening in the grille. The other bracket (if installed correctly) will fit into the back side of the grille bars sort of like a puzzle piece. I'll try to get you a good pic from the backside of a grille tomorrow.
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (Survivor Z16 Picture album)
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (Survivor 66 Picture Album)
jeffschevelle is offline
post #6 of 14 (permalink) Old Dec 30th, 09, 7:48 AM Thread Starter
jason
Ok it sounds like I have the correct emblem but I don't think mine is sitting correctly against the grill. I will take some pictures. In the next day or 2 Thanks for the replys.
Jason
post #7 of 14 (permalink) Old Dec 31st, 09, 10:34 AM Thread Starter
jason
THis is the emblem that was on my original grill? It just don't look correct
The backing plate looks the same as the aftermarket one I seen?
It just looks like it is sticking to far out off the grill?
Let me know if this is the original one please or what year it might be.
Jason
post #8 of 14 (permalink) Old Dec 31st, 09, 11:16 AM
You have the right emblem, just reverse the inside bracket. You hae it upside down...
Bad67SS is offline
post #9 of 14 (permalink) Old Dec 31st, 09, 12:02 PM
Send a message via AIM to FlameOut
This might help, even though I added this to a non SS car, I think it is correct
CarDomain Photos
My Progress Pictures
396 (402) .030" over
Edelbrock
Performer RPM Air Gap
Lunati 60203 / KB 0.180
domed pistons
Holley Street Avenger 770
Muncie M-22
12 bolt posi 3.31
FlameOut is offline
post #10 of 14 (permalink) Old Dec 31st, 09, 1:23 PM Thread Starter
jason
On the back of the emblem is the square part suposed to go throught the grill??? Or rest up against it?
post #11 of 14 (permalink) Old Dec 31st, 09, 1:30 PM
should go through it partly at the top. The top of your emblem should be resting against the front of the grill... the above pic is a good shot for reference...just have the pointed part of the backing plate facing downward
Bad67SS is offline
post #12 of 14 (permalink) Old Dec 31st, 09, 5:36 PM
good pic Bill, but you have the inside bracket upside down too!
Below is a pic of the correct installation. The pic is sideways and I don't know how to rotate it. Pic is taken from the driver's side (top of the emblem is to the left of the picture, bottom is to the right) -
Jeff Helms
post #13 of 14 (permalink) Old Jan 1st, 10, 10:25 PM Thread Starter
jason
Thanks for the replys, I turned the bracket around and it fit a lot better and it also looks correct now!
Jason
post #14 of 14 (permalink) Old Mar 27th, 10, 12:12 PM
Man the search thing on here is great! Had the same problem with my emblem, Now its right
tristatechevelle is offline
