1966 Chevelle Frame Interchangability - Chevelle Tech
post #1 of 5 (permalink) Old Sep 14th, 09, 4:49 PM Thread Starter
I know this sounds like many other posts, but I cannot seem to find definitive, non-contradictionary posts and websites.
I am searching for a new frame for my 1966 chevelle malibu HT. I know I can use a 67 frame with different rear springs.
My questions
1. Can I use other GM a-body frames (Lemans, skylark, etc)? What years and mods are required?
2. What other Chevelle years can I use, and with what mods? 64 or 65?
3. I know the elky are different and heard you can cut them, but REALLY what do you need to do? How much welding?
Thank you for your help. If anyone knows where to find a decent frame, with minor rust issues, please let me know. I am in AZ.
-Chris
66ProjectAZ is offline
post #2 of 5 (permalink) Old Sep 14th, 09, 5:01 PM
Ryan
Re: 1966 Chevelle Frame Interchangability
Hi Chris! You can use other A body frames as long as they are two doors as well. As you mentioned, four doors, wagons and El camino's won't work. don't waste your time cutting them to fit. You're in Phoenix, shoot over to Desert Valley Auto Parts and pick one up.
RyanNilcea05 is offline
post #3 of 5 (permalink) Old Sep 14th, 09, 6:11 PM
Way back when, I was into stock car racing and decided to switch from Pontiac to Chevy. Rather than build a whole new car, I cut the skin off my '64 GTO body and welded a '66 Chevelle skin onto it. Everything worked great except in the very rear, where it became apparent that the Pontiac frame was an inch or two longer than the Chevy frame had been. A little notching of the inside of the body in the rear was all it took to take care of it for me, since it was a race car it didn't have to be pretty.
Maybe it was just the '64 vs. '66 year difference, rather than the Pontaic vs. Chevy difference. I'd measure carefully first.
'66 Malibu, being built for NHRA N/SA class.
dmuller is offline
post #4 of 5 (permalink) Old Sep 14th, 09, 6:50 PM
Larry Joe
I used a 67 lemans which has the same length as a elky
I laid them side by side after the box ends on frame rails at rear tires
I cut it there and rewelded my old tail section to it works great
I also is not a load bearing point for the most part Had it blasted
Powder coated it black cant tell it. Here in Tulsa there is several hundred $
Difference between a Chevelle and a pontiac
blubu
blubu is offline
post #5 of 5 (permalink) Old Sep 14th, 09, 7:06 PM
Tom Lloyd
64-67 Chevelle 2 door and 4 door frames are the same.
Tom Lloyd
my 66
take my advice, I'm not using it.
floyd66 is offline
