1970 cowl induction flapper door - Chevelle Tech
post #1 of 12 (permalink) Old Dec 17th, 07, 6:12 PM Thread Starter
Ken
Okay I bought a repo hood and parts for the flapper door. the one that opens from top the parts I got dont fit or maby im putting it together wrong? also they Didnot send any bolts to bolt the bracket to the hood what do these look like and how does it assemble. Thanks in advance for any help. also I did a search here and found nothing Helpful.
crazychevelleman is offline
post #2 of 12 (permalink) Old Dec 17th, 07, 8:40 PM Thread Starter
Ken
Re: 1970 cowl induction flapper door
No one has ever installed the top flapper on the cowl induction hood before, using repo parts
post #3 of 12 (permalink) Old Dec 17th, 07, 10:46 PM
This dosen't immediately help your problem, but I would highly recommend buying a factory Assembly Manual for your car.
It will give you detail to the nut, bolt and washer on this, and every other question that you will likely have.
The first thing I do when I buy a car is buy an Assembly and Service Manual.
These are a must have.
You can likely contact your parts supplier tomorrow morning, tell them what your dilema is, and a good sales rep should be able to send you anything that's missing, and your new Assembly manual to help you solve this, and many other future questions regarding correct assembly details for your car.
Good Luck.
Happy motoring!
69396ss is offline
post #4 of 12 (permalink) Old Dec 18th, 07, 12:02 AM Thread Starter
Ken
The assembly manual does not explain this area in as much detail as I would like. I was looking for either pics or a person who has faced this problem.
post #5 of 12 (permalink) Old Dec 18th, 07, 12:27 AM
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
I agree with John.
Are you trying to put it together with the hood on the car? Its alot easier to do with the hood off.
I started with Nothing and still have All of Nothing!
Bad Brads 1969 Convertible SS
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
1badss396 is offline
post #6 of 12 (permalink) Old Dec 18th, 07, 12:39 AM Thread Starter
Ken
No the hood is off, the brackets they gave me does not have bolts to attach the flapper door brackets to the hood. I was wandering what the bolts look like, not bolts from the hardware store but the original bolts. looks as if it calls for 4. also the flapper pivot bolts dont fit the bracket, was just wondering if im am missing something however looks as if I might have to re-tap the brackets for the pivot bolts they sent me. Not that this is shocking, but its tiawain stuff. I was just wanting to make sure that I was on the right track, the assembly manual calls for the nylon washers to go on the outside of the door between the hood and the door just wanted to make sure this is correct because sum stuff listed in the assembly manual is off, you know what I mean.
post #7 of 12 (permalink) Old Dec 18th, 07, 8:08 AM
Ken, here is a picture of the flapper door pivot bracket bolts.
http://www.goodmarkindustries.com/gr...03%20COLOR.JPG
Mike72ss is offline
post #8 of 12 (permalink) Old Dec 18th, 07, 10:34 AM
Dana
Go here and search on cowl induction. http://www.ss396.com/chevelle_64-72.htm you'll find what your lookoing for...
70ChevelleRagtop is offline
post #9 of 12 (permalink) Old Dec 19th, 07, 1:29 PM
The the holes that mount the bracket to the hood and hold the door do NOT need to be tapped. They are thru holes.
Go to http://1964-77chevelleparts.com/cata...004%20fuel.pdf for a section of the Classic Muscle catalog with exploded views.
You can also plug the numbers from the catalog in here http://www.parts123.com/parts123/yb....hPage~cadeiijd to see what the item looks like.
Godspeed,
Dan Solomon
70 Chevelle - Fathom Blue
http://www.freewebs.com/chevelles1970/
"It is a mistake to allow any mechanical object to realize you are in a hurry."
dsolomon is offline
post #10 of 12 (permalink) Old Dec 19th, 07, 4:09 PM Thread Starter
Ken
Thanks guys
post #11 of 12 (permalink) Old Dec 19th, 07, 10:20 PM
Ken:
Don't forget to install the bushings between the hinge and the bolts or this will be sloppy. These look like a flanged washer and are plastic.
singlecruzer3 is offline
post #12 of 12 (permalink) Old Dec 20th, 07, 9:52 AM
Ken,
You may have issues with the flapper door alignment in the repro hood. I had to modify the hood area where the welded nuts are located for the door brackets. I actually had to cut the area out, bolt the flapper door to the piece I cut and once the door aligned properly, I welded it back. It had to be repositioned 3/16's of an inch to allow the door to align properly.
I also had to use several shims to get the door flush.
Ed C.
70 Cutlass Conv.
70 SS L34 Auto project
Always looking
EdCarpenter is offline
