Not sure if I did this right?/ holley mech. fuel pump - Chevelle Tech
2002 General Tech questions from 2002
post #1 of 3 (permalink) Old Jan 25th, 02, 9:18 AM Thread Starter
I need to feel at ease with this install. Here's the question: If the mechanical fuel pump bolts correctly to the block does that mean the rod stayed up and is in the right position? Or if the rod falls down can the pump still be bolted correctly to the block?
thanks.........bk
driverk is offline
post #2 of 3 (permalink) Old Jan 25th, 02, 10:06 AM
Driver,
If the pump rod slipped down, you would not be able to correctly mount the fuel pump to the block. In order to get the pump in, the rod has to be pushed in, so you must have doen it right.
Rod
Hotrod65SS is offline
post #3 of 3 (permalink) Old Jan 25th, 02, 12:44 PM Thread Starter
Thank you Rod!
driverk is offline
This Thread is more than 5629 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
