6 cylinder Tachometer to 8 cylinder. Electronic fun. - Chevelle Tech
2002 General Tech questions from 2002
post #1 of 2 (permalink) Old Feb 14th, 02, 9:21 PM Thread Starter
I was finishing a dash for my chevelle and, after wiring all my guages, I found that the tach I got was apparantly out of a 6 cylinder camaro. Last time I checked I had 8 cylinders. So that means I either have to put in a 6 banger distributor or convert this tach over.
I know it can be done, because I made a crude tach one time using LEDs and some special IC from RatShack. This tach could be switched to 4,6, or 8 cylinder pulses. Unfortunatly this was done at a time when I had more money, patience, and brains (painting with clearcoat took care of the brains I guess). However, I do remember some of you folk are rather handy with electronics. I happily welcome your suggestions here, and no, I ain't buyin' a new tach. Thanks!
SouthernThunder is offline
post #2 of 2 (permalink) Old Feb 14th, 02, 9:42 PM
Is a autometer tach? If so I think the way you make it for a 6cly is to clip a wire that loops at the base of the tach. If you splice that back together I think you are in business.
I know for a fact thats how it works for a 4cyl from back in my aircooled VW days.
gearheads78 is offline
This Thread is more than 5551 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
