67 Bench 4spd Floor Hump - Chevelle Tech
post #1 of 8 (permalink) Old Apr 20th, 17, 9:29 PM Thread Starter
Billy
HI , I am changing a column shift 3 spd to a 4 spd floor shift bench seat . I have the cast chrome part that goes above the carpet but need the tin floor hump . Has anyone here had success finding the correct piece ? Ausley's sold me one that is not even close to fitting .
Duce is offline
post #2 of 8 (permalink) Old Apr 20th, 17, 10:56 PM
Re: 67 Bench 4spd Floor Hump
Im glad Im not the only one with the same issue. I bought one from one of the restoration places and like you, not even close for a 66. I tried pounding it, forming it. Finally got fed up and installed a bigger shift boot and called it a day. I think I saw the twisted piece of tin on my shop table the other day. No idea why I even kept it. jim
66 chevelle 350 4 speed latest project.
Jim Mac is online now
post #3 of 8 (permalink) Old Apr 20th, 17, 11:40 PM
Pat
I got one from NPD a few years ago and dropped right on tunnel like a glove. might want to give them a shot.
myrusty66 is offline
post #4 of 8 (permalink) Old Apr 21st, 17, 12:36 AM
Summit racing
Npd*
Opgi*
Just picked up both styles for my 68 that I am converting
GoFast Beaumont is online now
post #5 of 8 (permalink) Old Apr 21st, 17, 6:42 AM
Don
Not sure about "67" but as far as I know from all the research I've done the "66" uses the same tunnel hump for all floor shift applications,three speed,four speed and auto trans.Most vendors list the wrong one for the Chevelle,I think the tall one they sell is for Pontiac and Buick A bodys of this era. Order the shallow one listed for the floor shift automatic and you should be good to go,thats what I did on my"66" and it fit the tunnel perfectly.If you search the forums on this site you'll find plenty of info and pic's on this issue. Good Luck.
Don B is offline
post #6 of 8 (permalink) Old Apr 21st, 17, 9:13 AM
Kevin
I fabbed one up for my '67 auto to 5 speed conversion. Fairly easy and works great. I ran into the same issues with factory reproductions that didn't fit. Then again, I had to slightly modify the tunnel for the trans to fit.
"If your not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
FAST EZ EFI
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #7 of 8 (permalink) Old Apr 21st, 17, 5:38 PM
The sheet metal hump for a 4 speed bench is different from others as you have found out. I don't believe it is being reproduced but I could be wrong.
Dan Anderson
TC#1053
ACES#4161
dbasdan is offline
post #8 of 8 (permalink) Old Apr 22nd, 17, 8:51 PM Thread Starter
Billy
Thanks for the help so far , Has anyone done a conversion and installed the factory 67 chrome cast part that installs above the carpet ?
This is the part I want to mount .
Original 66 67 Chevelle Chrome Bezel 3903960 4 Speed w/o Console Beaumont SS | eBay
Duce is offline
