12 bolt Pinion Yoke Question. - Chevelle Tech
post #1 of 1 (permalink) Old Apr 21st, 05, 10:48 PM Thread Starter
I have a 12 bolt out of another 70 chevelle and it has a 1330 series U-joint and straps with bolts. I remember reading that there where two types of yokes, one with staps and one with U bolts. One was a small block rear, the other a big block rear. Anyone know which is which and which one that I have?
I was going to use a jump joint (my shaft is a 1310), but I need to get my shaft cut down to fit the super T10 that I'm putting in so I'm thinking of getting a new 3 1/2 inch shaft with 1330 joints. What do you guys think?
Thanks,
David
-=1970 Malibu - 454, 4spd, 3.73 12 Bolt Posi =-
http://www.middletoninv.com/Chevelle
cobra2411 is offline
This Thread is more than 4449 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
12 bolt pinion yoke part number? 70badboy Transmission & Driveline 2 Feb 27th, 05 10:02 AM
12 BOLT YOKE QUESTION SWHEATON Transmission & Driveline 7 Sep 22nd, 04 9:19 PM
help with 12 bolt question asbill71 Transmission & Driveline 8 Apr 20th, 04 12:33 PM
12 bolt question MalibuMike70 Transmission & Driveline 2 Feb 25th, 04 6:06 PM
one more pinion flange question blm Transmission & Driveline 4 Feb 12th, 03 7:58 PM
