Vac. modulator on blower motor - Chevelle Tech
post #1 of 4 (permalink) Old Dec 14th, 03, 11:28 PM Thread Starter
Post
This is for a friend of mine, hes building a blown BB. It will have a turbo 400 & is wondering the best way to hook up the vac. modulator , carb base vac. or below the blower or would it be better to use a cable operated modulator??
77 Monte
421 Profilers ported by Eric W. Straub HR 3200 conv. from Jake 200-4r w/ 3.73's
12.15 @ 112 & tuning
http://myweb.midco.net/77cruiser/
77 cruiser is offline
post #2 of 4 (permalink) Old Dec 14th, 03, 11:37 PM
jakeshoe
Guest
Posts: n/a
Post
77,
A friend of mine ran a TH350 behind a 6-71'd SBC and the vacuum off the back of the carb worked fine.
On a TH400,
you can get the mechanical modulator off a diesel application...
Good luck.
post #3 of 4 (permalink) Old Dec 15th, 03, 6:21 AM
Post
The the mechanical modulator setup off a diesel application, mentioned above is best way to do this right.
Pro Built Automatics is offline
post #4 of 4 (permalink) Old Dec 15th, 03, 10:06 AM Thread Starter
Post
I ran one way back when hooked to the carb base & not a problem, but I told him I might be concerned about too much vac. @ part throttle. I don't know how much vac. you get @ P/T on these apps. I never checked mine only @ idle which was 10 in.
He works @ a GM dealer so the mechanical one would be no problem.
