200r4 rebuild questions - Chevelle Tech
post #1 of 5 (permalink) Old Sep 16th, 02, 12:34 PM Thread Starter
Send a message via Yahoo to jmhardin
Are these easy to rebuild? I understand I need a "clean" area to do this. I have never done a rebuild and would like some clear written instructions. I want to install a performance shift kit too. Is this tricky?
jmhardin@yahoo.com
1967 Chevelle Malibu - Granada Gold & Capri Cream
1965 SS Convertible - Crocus yellow with black top
The 67 Beast before restore
Parts needed/wanted
Team Member 1756
Kids in the back seat cause accidents.
Accidents in the back seat cause...kids.
jmhardin is offline
post #2 of 5 (permalink) Old Sep 17th, 02, 1:48 AM
They are kind of hard to because they have a lot more parts than a 3 spd. auto. If you decide to take it on get an ATSG service manual or one from GM & see what you are getting your self into.
77 cruiser is offline
post #3 of 5 (permalink) Old Sep 17th, 02, 9:25 AM Thread Starter
how about just the performance kit? Are they easy?
Would also like some advise on transmission coolers, where and how to mount them, torque converter selection, shift kit selection. I have 3.36 rear gears, 200-4R transmission from a boneyard, 355 SBC stock. I want good low end torque, chirping tires, fun driver. This car will not go to the track much, if any.
jmhardin@yahoo.com
Parts needed/wanted
Team Member 1756
[This message has been edited by jmhardin (edited 09-17-2002).]
jmhardin is offline
post #4 of 5 (permalink) Old Sep 17th, 02, 11:02 PM
JM, Look at the "living with 2004" thread. Transfixleo nails it right on with the transgo shift kit and i would look at other items he has written. When getting a trannie cooler "get a biggie" and make sure it has stacked plates, I personally run 2 B&M stacked plate coolers in series to the side of my rad. Remember on a 200 trannie the pressure line is on the upper sooooo on and out to the radiator (lower)then out upper to the external cooler and back to the trannie.
One good this about running it this way is if it gets to cold you can cover up the external and the rad warms it up. Right now in the heat "110+" my trannie runs 170-180 all day long. Good luck
Jim Elliott is offline
post #5 of 5 (permalink) Old Sep 18th, 02, 2:39 AM
A company called "Technical Video" makes excellent tapes on how to rebuilt transmissions. You can get them through Eastwood and maybe direct. I have the one for the TH350. Very easy to understand, step by step.
jpete is offline
