700R4 Shift Shaft Metric Thread or Not - Chevelle Tech
post #1 of 4 (permalink) Old Jun 9th, 03, 9:07 PM Thread Starter
Rob
Post
I'm installing a shifter kit made to hook up to my steering column. Is the shifter shaft nut metric thread.
I have put a 3/8 course thread nut on but it wont start
Brob is offline
post #2 of 4 (permalink) Old Jun 9th, 03, 9:24 PM
Jack
Post
Brob
Most likely is..I know the case bolts are metric
for sure..Can't specifically remember on the shift shaft..
Importtech is offline
post #3 of 4 (permalink) Old Jun 9th, 03, 10:05 PM
Post
the complete tranny is metric threads
the manual shift shaft is 10mm x 1.5 threads
Tony....
Yelsorc is Crosley backwards.
Yelsorc is offline
post #4 of 4 (permalink) Old Jun 9th, 03, 10:33 PM Thread Starter
Rob
Post
Thank You for the information I will be more cautious.
Brob is offline
This Thread is more than 5099 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
