Should I Change From 3.55's To 3.31's - Chevelle Tech
post #1 of 6 (permalink) Old Jun 10th, 03, 1:33 PM Thread Starter
Steve Johnson
Post
It is being suggested that I switch the gearing on my 70 with 454 LS6 to 3.31's. Will this be worth the cost and effort to make this change.
http://www.chevelles.com/showroom/da...rofile_pic.jpg
1970 SS with a .030 over 454 LS6 crate engine, 14096188 open chamber rect. cast iron heads, 3933163 intake, Quick Fuel Q850PV, Summit 110gph FP, Holley 12-803 fuel pressure regulator set to 7.0 psi, Bullet cam (238/245 @ .050, lift 540/540, LSA 109), Gm HEI 93440806, TH400, FTI 3500 convertor, Hedman headers, 2.5" exhaust with H-pipe, Pypes Race Pro mufflers, 3.55 gears, KYB gas shocks, UMI adjustable upper control arms and UMI boxed lowers, pinion angle negative 1-2 degrees), 245/60/14 BFG's and M/T Pro Bracket Radials, timing total 37 degrees.
1.725 60', 11.937 @ 111.91mph
Steve Johnson is offline
post #2 of 6 (permalink) Old Jun 10th, 03, 2:17 PM
Post
Well, let's see, 3.31/3.55 = 93.24%
I'm not sure what you are trying to achieve, but the reduction in RPM for highway driving would only be 7%, probably only about 200RPM, and the performance differntial would be negligible.
Georgia69 is offline
post #3 of 6 (permalink) Old Jun 10th, 03, 2:33 PM
Post
Where are you going to get the 3.31's? Just curious as I have not seen them available anywhere other than used on Ebay.
In it for the short haul
Midnight Marauder is offline
post #4 of 6 (permalink) Old Jun 10th, 03, 3:49 PM Thread Starter
Steve Johnson
Post
Thanks Mike, that's kind of what I felt. Your ratio shows that the reduction in rpm is neglible.
post #5 of 6 (permalink) Old Jun 12th, 03, 9:07 AM
mr 4 speed is offline
post #6 of 6 (permalink) Old Jun 12th, 03, 10:04 AM
Post
You can get that much change with a larger tire.
3.31 is hard to find, It's 3.08 or 3.42 new.
JMOP Bob J.
Bob Johnson is offline
This Thread is more than 5067 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
