Bell Housing dial in - Chevelle Tech
post #1 of 17 (permalink) Old Aug 25th, 14, 1:33 AM Thread Starter
Cory
This is no fun at all doing by yer lonesome. Especially since it was .023 out from perfect and I only had .007 offset dowels. At least I had the motor out and and on hoist and blocks.
That's what happens after line honing the block I suppose. The offset was such that I needed to raise the housing strait up.
Long story short, I ended up with a 7/16-20 shoulder bolt drilled and tapped through the Lakewood Housing into the top block bell housing boss.
After blocking and shimming the housing up from the bottom I was able to get it dialed in at .001 and drilled a pilot hole followed by the the proper bit for tapping.
Buttoned it all up and I got lucky. The .001 didn't change.
The story ain't over. I ordered the .021 offset dowels from http://www.robbmcperformance.com/products/dowels.html
which are much better than the .007 style that I had.
A 2 hour job crammed into 12...and I still have to redo the whole thing after the new offset dowels get here.
BTW - GREAT CUSTOMER SERVICE FROM robbmcperformance.com and on SUNDAY , NO LESS.
'66 SS 396 #'s match/ POP - Aztec Bronze / Bronze Interior
'66 SS 454 Cortez Silver / Maroon Interior
'37 Chevy Coupe 235 Straight 6 - Cabana Cream`
'55 Chevy Gasser - 427, 4 speed
dream66 is offline
post #2 of 17 (permalink) Old Aug 25th, 14, 8:41 AM
Jody
Re: Bell Housing dial in
You do realize that a bellhousing needs a parallel alignment check too. The parallel alignment check/repair must be done first as it will change the actual concentric alignment reading.
Jody Haag
JodysTransmissions@verizon.net
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
Autogear 4 Speed Distributor
Legend700 5 Speed Distributor
Jody's Transmissions on Facebook
JodysTransmissions is offline
post #3 of 17 (permalink) Old Aug 25th, 14, 8:50 AM Thread Starter
Cory
Thanks,
I haven't seen the parallel spec tolerance or the method to measure it.
Do you have the specs or a link to them?
How do I correct it if out of tolerance? Machine shop?
dream66 is offline
post #4 of 17 (permalink) Old Aug 25th, 14, 10:50 AM
Jody
Here is a picture reference for checking the parallel alignment. Parallel alignment is corrected by installing shims between the bellhousing and engine block.
Standard Automotive Bellhousing Alignment Specifications:
Concentric: +/-.005 or .010 TIR
Parallel: +/-.001 or .002 TIR
Hi-Performance 7,500+ RPM Bellhousing Alignment Specifications:
Concentric: +/-.0025 or .005 TIR
Parallel: +/-.0005 or .001 TIR
Jody Haag
610-413-8015
post #5 of 17 (permalink) Old Aug 25th, 14, 11:26 AM Thread Starter
Cory
Thanks Jody. It's a great confidence builder to be able to nail these specs down and achieve them on my projects.
From the pic it appears that the mag base is mounted on the flywheel which is rotated do perform the check just outside the opening in the bell.
dream66 is offline
post #6 of 17 (permalink) Old Aug 25th, 14, 8:28 PM
Jody
Here is a 5 page bellhousing alignment procedure I wrote up for the Legend700 transmission warranty. Anyone can print these 5 pages and use them for any manual transmission install.
Jody Haag
610-413-8015
post #7 of 17 (permalink) Old Aug 26th, 14, 2:36 AM
Jody, this is excellent. Thanks for taking time. Stuck to the top.
post #8 of 17 (permalink) Old Aug 26th, 14, 8:52 AM
Jody
Tom, Thanks for making this a sticky.
Bellhousing alignment is probably the most over looked procedure.
I am here if anyone has any questions..........
Jody Haag
610-413-8015
post #9 of 17 (permalink) Old Aug 26th, 14, 6:34 PM
where do you get the shims for the parallel alignment? Are they store bought?
USN-SSBN 645-G
boyd66k20 is offline
post #10 of 17 (permalink) Old Aug 26th, 14, 6:38 PM
Kelly
You can get shims from Granger or other industrial supply houses. Ask for "A" shims.
Mechanicsn is offline
post #11 of 17 (permalink) Old Aug 26th, 14, 10:08 PM
Jody
Yes, Grainger or MSC Direct will have the needed shims. Here is a reference picture of what I use. The correct shim size you need will have a 3/8" bolt slot and I suggest you buy .001" through .010".
Jody Haag
610-413-8015
post #12 of 17 (permalink) Old Oct 20th, 14, 6:07 PM
Michael
Am I missing something. Never thought about alignment issues. What could arrise from misalignment?
Choctaw is offline
post #13 of 17 (permalink) Old Nov 21st, 14, 5:49 AM
Greg
lots of things! premature clutch failure, excessive pilot bear wear, ruined trans input bearing, difficulty shifting under load, vibration, and broken transmission case. ever seen a trans at a swap meet with the ears broken off? this is why.
66 chevelle 300, lunati 408, tko 600 3:55 12 bolt UMI rear control arms, and lower control arm relocation kit, JGC power steering
56 sedan delivery project 327, 700r4 coilover heidts control arms
2 Harleys
a nice wife
a nice house
a nice pitbull dog
fastlane666 is offline
post #14 of 17 (permalink) Old Dec 4th, 15, 1:44 PM
Hey Fellas,
I have a Saginaw 4 Speed and I am looking at a T-56 , 6 speed. My question ...is what bell housing will be required for a 350 SB? I have already changed over to a McLeod Hydraulic Clutch System
Army Guy is offline
post #15 of 17 (permalink) Old Feb 2nd, 16, 4:25 PM
What will happen if the bell housing is not aligned. Can this cause a shuddering type vibration in the driveline
Ed habuda is offline
