This is the why/how I always install a magnetic drain plug in Muncies - Chevelle Tech
post #1 of 20 (permalink) Old Apr 18th, 12, 4:19 PM Thread Starter
I'm rebuilding a 68 Muncie for a customer and this is typical of what I find inside. The 63-69 Muncies did not have a drain plug (except M22s). But ALLLLLLLLLLLLL Muncie cases have the boss for a drain plug. The 63-69 Muncies have a magnetic donut glued to the bottom of the case. There is NO WAY to drain the tranny, nor is there any way to remove the accumulation of metal particles from the donut magnet (without removing the tranny).
This is typical of what I find inside a hi-mileage/well used Muncie. You can see the outline of the donut which is covered with sludge/tiny metal particles.
Same case with all the guts removed.
The removed and cleaned donut.
As I mentioned, ALLLLLLLLLLL Muncie cases have a boss for a drain plug.
I start out with a pilot hole to assure it will be centered and straight in the boss.
Then drill a larger hole (11/16 drill bit).
The hole is tapped with a 1/2in pipe tap.
With a magnetic drain plug installed, the oil can be drained and changed, BUT, it also permits removal of any metal particles which can continue to circulate in the tranny and cause continued wear to gear teeth and bearings.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #2 of 20 (permalink) Old Apr 18th, 12, 6:51 PM
Jerry
Re: This is the why/how I always install a magnetic drain plug in Munc
Great pictures and demo Tom
Jerry
65 Beaumont
L96 6 Liter
Straub hyd. roller
Tremec 5 speed
http://www.chevelles.com/showroom/da...e_Rims_014.jpg
blumont is offline
post #3 of 20 (permalink) Old Apr 18th, 12, 8:30 PM
leo
Mods, can we sticky this post in the Trans section? Please.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
www.mdchevelleclub.com
LeoP is offline
post #4 of 20 (permalink) Old Apr 19th, 12, 4:35 AM
done
post #5 of 20 (permalink) Old Apr 19th, 12, 8:10 AM
"Wild Bill"
A great tip Tom!!
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #6 of 20 (permalink) Old Apr 19th, 12, 1:35 PM
leo
Thank You Tom Mobley.
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #7 of 20 (permalink) Old Apr 24th, 12, 9:57 AM
Is that amount of sludge "normal" in a muncie? Seems like a drain plug could only capture SOME of that amount of mess.
novadude is online now
post #8 of 20 (permalink) Old Apr 24th, 12, 10:36 AM
...it also permits removal of any metal particles which can continue to circulate in the tranny and cause continued wear to gear teeth and bearings.
How would you suggest removing the metal particles that don't just drain out with the old oil?
Wiggle a telescoping magnet around inside?
Flush with mineral spirits or thin motor oil?
First one, then the other?
_____________________________________
68 Chevelle
flat top 406, AFR 195's, XR286R, RPM AirGap
750 Holley DP,TH400 w/brake, 4000 stall FTI
3.31 gear, 12 bolt
... for now.
Yellomalibu is offline
post #9 of 20 (permalink) Old Apr 26th, 12, 1:30 PM
Nate
Well done write up.
Our case comes with a magnetic plug already; however its a good addition for a drivers car. A mag plug wont catch everything, but its a definite help, along with changing the lubricant
Auto Gear is offline
post #10 of 20 (permalink) Old May 3rd, 12, 11:13 PM
Ron
I have followed this exact advice from Tom some 10 years back on adding the plug. Worked great!!
A tip for someone going to do this who is new to using a pipe tap - you can sort of tap the hole too deep if you aren't careful. The threads are tapered and so you can't run the tap through like you would with a bolt tap. Run your tap about 2/3 of the way in and then check it with your plug. The plug ideally would not go as deep as flush to the case I think, though if it did that'd be ok, just try to avoid going deeper than that.
Ron Cook
'69 300 Deluxe SS396
My GM Canada Documentation
Founding member of The CanAm Chevelle Club
Bow_Tied is offline
post #11 of 20 (permalink) Old May 4th, 12, 11:12 PM
Excellent point about tapping too deep if your not careful. Good job!
66 chevelle in the works
Team Chevelle Member #:2361
money pit
In God we Trust! USA
66dream is offline
post #12 of 20 (permalink) Old Jun 5th, 12, 11:52 AM
Originally Posted by Auto Gear View Post
Well done write up.
Worked for me.
I found two drive teeth from 2nd gear and the detent pin from my 1-2 shift fork stuck to the drain plug magnet.
These parts would have caused serious damage if left tumbling around.
This is the AutoGear Supercase and drain plug.
#1104
1969 Chevelle 460, 3.73 posi
Auto Gear Super Case with M22 gears
12.11 @108 mph
Top speed 114.23
SS_Dave is offline
post #13 of 20 (permalink) Old Jun 7th, 12, 12:48 PM
Ive noticed that boss on my muncie and wondered if anyone ever did this. Why GM never just went ahead and drilled and tapped it from the beginning is a mystery, but at least the boss is there to do it at home.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline
post #14 of 20 (permalink) Old Sep 19th, 12, 7:49 PM
Great info, I have a 67' M21 in my car - it has a drain plug. Someone must have added it before I got it.
1972 SS 454 Chevelle - 468/M21/3.73
1969 Malibu L48/M20/3.31
Originally Posted by 69-CHVL View Post
How do you retire from something you rarely do?
Its like a welfare reciepiant saying there done working...
carpoor is offline
post #15 of 20 (permalink) Old May 20th, 13, 5:39 PM
My "Spare" M20 still has one of two teeth from 1st gear stuck to the magnet. I am going to get a new gear, then rebuild it.
El Guapo is offline
