200-4R transmission swap 64 chevelle - Chevelle Tech
post #1 of 9 (permalink) Old Feb 20th, 12, 8:01 PM Thread Starter
Henry
Hey Chevelle people! Does anybody know where to obtain, or can provide a complete, and I emphasise complete, set of installation instructions, to install a 200-4R, from a 1981 chevy malibu, into a 1964 chevelle with an unmodified 283 cu.in. 2bbl and a powerglide transmission? I am going to make this swap and also change rearend ratio to obtain an increase in fuel MPG. My car is a bone stock survivor and I will keep removed parts to go along with car should I ever sell it. Thank you in advance for your time and effort
henryc2 is offline
post #2 of 9 (permalink) Old Feb 22nd, 12, 9:18 PM
Re: 200-4R transmission swap 64 chevelle
Here is some info that may help with swapping a 200-4R.
http://www.chevyhiperformance.com/te...wap/index.html
http://www.chevyhiperformance.com/te...all/index.html
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline
post #3 of 9 (permalink) Old Feb 22nd, 12, 10:18 PM
Kevin
Should be a pretty easy swap. I put one in my '67 a couple of years ago. The PG and 2004-R are the same length and the splines are the same on the driveshaft. The only slight challenge is the TV cable linkage. I suggest using a Bowtie Overdrives TV made EZ setup as it makes set up a snap. If you have a column shift PG, use a Kugal for the linkage as it makes it easy as well. Other than that, should take a few hours to complete.
"If your not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
FAST EZ EFI
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #4 of 9 (permalink) Old Feb 23rd, 12, 8:52 PM
Scottie
super easy swap it will; all bolt right in just redrill new holes for your cross member about 6.5 inches farther back and your done
My Big Block Chevy Head Bolts Require More Torque Then Your Honda Makes
Check out the kids Ride!
http://www.youtube.com/watch?v=OJ3Yt...ature=youtu.be
1971 Chevelle SS
496BBC sold
4L80E with a 3500 stall
Moser 12 bolt W/3.73 gears
BigChevyFTW is offline
post #5 of 9 (permalink) Old Feb 23rd, 12, 11:14 PM
don't think 200-R4 were made in 81, might want to check and see if you have a TH-200 non-OD. easier now than later.
post #6 of 9 (permalink) Old Feb 24th, 12, 11:11 AM
Greg.
Could be a transplant from a 1981 - 1990 OLDs 88 / 98 !
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
Now 468/Th400 2,500 stall/ S60 3.70 Gs
Prev M&H MSS001 street Tires/dress 2015/9/20
60' = 1.756 1/8 = 7.815 et / 89 mph
1/4 = 12.253 et / 111 mph
NEW Best on M/T S/R #6641 street Tires/dress 2016/10/9
60' = 1.720 1/8 = 7.747 et / 89 mph
1/4 = 12.112 et / 112 mph
Kirk's67SS is offline
post #7 of 9 (permalink) Old Feb 26th, 12, 9:34 AM Thread Starter
Henry
Sorry typo it should be 82
henryc2 is offline
post #8 of 9 (permalink) Old Feb 26th, 12, 10:17 AM
Steve "Dirty"
The number one thing that you need to be scientific is with the tv cable geometry or it will burn out the transmission in a heartbeat. Transgo had a series of things to check for the longevity and shift qualities. Pay attention to this one detail. I used to be a transmission Tech (22 Yrs Experience) when these trannys were very popular.
modchevelle is offline
post #9 of 9 (permalink) Old Mar 4th, 12, 6:54 PM Thread Starter
Henry
Thank you one and all the info is greatly appreciated.
henryc2 is offline
This Thread is more than 1940 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
