69 chevelle drive shaft - Chevelle Tech
post #1 of 1 (permalink) Old Jan 7th, 12, 12:34 PM Thread Starter
RWS
Will the existing drive shaft (Automatic TH350 now) work when changing over to a manual as far as length, etc? I've been told it will. Also the yoke coming out of the automatic I think is 27 spline, is that the same for Muncie also? Or will I need to cut or lengthen driveshaft and/or buy a different Yoke?
Thanks,
RwS
RWS is offline
This Thread is more than 1938 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
