Can an M22 be built to take a 650HP/650ft-lbs? - Chevelle Tech
post #1 of 14 (permalink) Old Nov 24th, 11, 1:03 PM Thread Starter
I have a 496 in the car with Canfield 310 heads, and I'm about to have Chris Straub grind me a hyd-roller. Is there any way to build a munci that can live behind this beast?
1971 SS454 LS5, Tuxedo Black / Black interior.
496, M22, 12 Bolt 4.11
http://s1100.photobucket.com/albums/.../1971%20SS454/
SethT is offline
post #2 of 14 (permalink) Old Nov 24th, 11, 1:23 PM
Re: Can an M22 be built to take a 650HP/650ft-lbs?
Probably not,there is a company that makes a super Muncie (auto gear)chech into tree trans. Greg
greg5436 is offline
post #3 of 14 (permalink) Old Nov 24th, 11, 2:23 PM
Michael
Send a message via AIM to MEJ1990TM
It comes down to tires, and how it will be driven. You could put a Saginaw behind that if you drive it like an old lady.
The drag racers I knew ran M22's deep into the tens at probably that same power level. After really thrashing them they each broke one. At the very least you should probably get Super Case and put your OEM internals in it. Even better would be to get a new Auto Gear transmission built by a reputable builder.
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
MEJ1990TM is offline
post #4 of 14 (permalink) Old Nov 24th, 11, 2:27 PM
Larry Joe
Anything can be broke
blubu
blubu is offline
post #5 of 14 (permalink) Old Nov 24th, 11, 5:03 PM
Todd
I AM PUTTING an m20 behind a 13 to 1 461 with a hyd roller
72 Chevelle ( malibu but it identifies as a W code LS-5 car)
70 Nova 540 ,powerglide SOLD
67 El Camino
2007 300C
2000 Chevrolet crew cab dually
2007 Honda VTX 1300C
1998 S10 rust bucket
Tod74 is offline
post #6 of 14 (permalink) Old Nov 24th, 11, 5:27 PM
No. And the type of clutch will either extend the inevitable or not. You'll eventually need to go aftermarket at that power level. Our 67 runs 125-150 HP below that and the AutoGear M22Z is only "enough" imho.
post #7 of 14 (permalink) Old Nov 25th, 11, 10:29 AM
Just do NOT dead hook!
TC#3095
dreis454 is offline
post #8 of 14 (permalink) Old Nov 25th, 11, 10:45 AM
Nice thread, hate to hijack it, but this seems like a good place to ask Muncie/power questions.
How about an M21 behind 430HP/430TQ? Will it be reliable?
1965 Chevelle 300 2dr Post Sedan
Project: High School Sweetheart
http://i198.photobucket.com/albums/a...edCar65085.jpg
Project High School Sweetheart Thread: http://www.chevelles.com/forums/56-pro-touring/352238-project-high-school-sweetheart-65-chevelle-2dr-post.html
cgocifer is offline
post #9 of 14 (permalink) Old Nov 25th, 11, 10:56 AM
IMO, as long as you don't run slicks it will last a long time....
TC#3095
dreis454 is offline
post #10 of 14 (permalink) Old Nov 25th, 11, 11:00 AM
I've had the tranny in a 65 Chevelle for over 25 years with zero problems other than having to double clutch 4th gear (typical). I'm having it rebuilt with some later year goodies by Jerry MacNeish. I've never had it behind more than about 300hp, but that's going to change. Hope it holde up! :-)
Project High School Sweetheart Thread: http://www.chevelles.com/forums/showthread.php?t=352238
cgocifer is offline
post #11 of 14 (permalink) Old Nov 25th, 11, 11:11 AM
Doug
There are so many variables,every combo will be different.Tires,driving habits,and suspension condition.One thing I learned a long time ago,is if you dump the clutch with a subpar suspension,there is hardly a transmission built that will hold up.Wheelhop is like a huge jackhammer,knocking the gears back and forth.The constant on off,on off,rapid release and then grabbing of traction will murder your trans in a short order.I ran a stock M-20 in the low 11's with slicks on a heavy car,constantly,never hurt it,but it had a tight suspension.I had a high 13 second 55 Chevy when I was a kid in the 60's,with an M-21 that I busted the countershaft in twice before I figured out it was a shot suspension doing it.
70 SS 454 LS-5 M-22 Bornwith Drivetrain-Sold New Baldwin Chevrolet
72 SS 454 El Camino W Code-427 4spd.
60',1.46, 6.63@103.59 10.45@128.1
My Showroom
Resto Pics http://www.chevelles.com/forums/35-r...tion-pics.html
DougA is offline
post #12 of 14 (permalink) Old Nov 25th, 11, 11:34 AM
Michael
Double clutch as in push the clutch in, take the trans out of gear, release the clutch, push the clutch back down, and then shift into gear? If that is the case, no, that is not typical. You should be able to shift proper working Muncie without having to double clutch.
post #13 of 14 (permalink) Old Nov 25th, 11, 1:26 PM
Jody
You need to post more stats about your car and driveline.
Flywheel weight?
Clutch?
Differential gearing?
Rear tires?
As others have mentioned;
Autogear Supercase/Iron midplate or a Doug Nash cast iron Muncie case.
Reduce the endplay/axial movement of the cluster gear
Add extra maindrive gear shim
Preload the transmission/gearset/driveline before you do a holeshot!
Jody Haag
JodysTransmissions@verizon.net
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
Autogear 4 Speed Distributor
Legend700 5 Speed Distributor
Jody's Transmissions on Facebook
JodysTransmissions is offline
post #14 of 14 (permalink) Old Nov 25th, 11, 4:47 PM
As in, push the clutch in, shift from 3rd to... grind, release clutch, push clutch back in, and shift into 4th.
Not typical for normal ops, but a typical issue as these age. My synchros were old and needed some work.
cgocifer is offline
