67 Z bars and clutch rods, OEM and repop - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old Mar 21st, 13, 8:11 PM
Re: 67 Z bars and clutch rods, OEM and repop
Who sells the best clutch rod for a 67.
According to the catalogs of NPD and Ground Up......they are very different.
I have been using my clutch rod from a kit I got from OPG back about 20 years ago, worked fine on my car, but I have been having to try and bend it with a torch to get the right angle so I dont hit the open in the firewall with it. You would think my Dads 67 would fit just like my 67, NOT.
Aaron is offline
post #17 of 20 (permalink) Old Mar 25th, 13, 8:29 PM
Re: 67 Z Bars 396
Originally Posted by Gary 396 View Post
A Photo of the 67 Clutch Pedals shows the wide bend in the After Market Clutch Rod that hits and interferes with the Frame of the Clutch Pedal Assembly which causes interference and binding. Also a Photo of an Original Clutch Rod End that is properly machined with the tight 90 degree end which gives more clearance away from the Clutch Pedal Frame and allows a smoother operation to disengage the clutch.
Gary
That is the same problem I got from a 67 pushrod from NPD.
The other (smaller bend) pushrod is from OPG about 20 years ago.
Of course, Im in the process of making the smaller bend one work on my Dads 67
Check out my thread here
67 4 speed setups
Aaron is offline
post #18 of 20 (permalink) Old Mar 15th, 14, 9:53 PM Thread Starter
Gary
Topic: Clutch Spring L Bracket Location Measurements for 1966 and 1967 Chevelles with 4 speed Transmissions. I have searched extensively for the correct measurements for locating the Clutch Spring L Bracket and have found a Post and Photos provided by Terry a.k.a. xoldschlracer66 on chevelles.com The web addresses are firewall clutch return spring bracket and http://s776.photobucket.com/user/twa...09992.jpg.html The measurements are 2 1/2" inches under a floor lip (which is located below the speedometer hole for automatic trans) and 4 1/2" inches starting from the left side of body support bracket. See attached Terry Photos.
Name:	!$1A  ClutchSpringBracket #1.jpg
ID:	155009   Click image for larger version
Name:	!$1B  ClutchSpringBracket #2.jpg
ID:	155017   Click image for larger version
Name:	!$1C  ClutchSpringBracket #3.jpg
Gary 396 is offline
post #19 of 20 (permalink) Old Aug 13th, 14, 9:12 AM
you guys are awesome. i just had to bump this because of the heim jointed linkage on teh first page. thank you to all who contributed. you just made my conversion that much easier.
iakona is offline
post #20 of 20 (permalink) Old Oct 7th, 16, 1:07 PM
Awesome reference sticky!! Is there a difference between a big block and small block Z bar and rods on a mid/late 67 Chevelle? If so, what is the difference and how can you determine the difference?
Kopfjaeger is offline
