87 chevy 1/2 ton - Chevelle Tech
post #1 of 7 (permalink) Old May 1st, 11, 8:07 PM Thread Starter
JOHN
87 chevy 1/2 ton
I picked up an 87 chevy 1/2 ton 2 WD with a 4.3 fuel injected V6 in. This is an overdrive truck. My question is, what transmission is under it? I'm assuming a 700R4, but not sure. Is so, is this trans. worth hanging on to? Thanks
If you borrow something more than once, you need your own!
TRANNY SMOKE is offline
post #2 of 7 (permalink) Old May 1st, 11, 10:06 PM
AKA Zombietroll
Re: 87 chevy 1/2 ton
I think 87 was the year they made improvements to the input shaft and valve body so if that's true Id hang on to it for a bit anyway.
zombie1969 is offline
post #3 of 7 (permalink) Old May 1st, 11, 10:27 PM
It might have the aux. valve body in it as well.
slingslingbinks is offline
post #4 of 7 (permalink) Old May 1st, 11, 11:14 PM Thread Starter
JOHN
I'm not sure what you mean by this? What trans. is in the truck? Thanks
post #5 of 7 (permalink) Old May 1st, 11, 11:18 PM
If the trans has an ext. housing on it it is a TH700, If the case is all one piece and no ext. housing it's a 200r4. Yes on hang onto the tranny. Is that what u wanted to know?
post #6 of 7 (permalink) Old May 1st, 11, 11:22 PM
& Administrator
If you have the whole truck ,look at the tag on the glove box door for the trans RPO code -believe it's MXO for the 700r4.
The 87 700r4 did have the aux. valve body and the improved input shaft.
Mike is offline
post #7 of 7 (permalink) Old May 4th, 11, 6:49 PM Thread Starter
JOHN
I found the MXO code on the glove box door. It must be a 700R4. Thanks
