How strong is a super T-10? - Chevelle Tech
post #1 of 26 (permalink) Old Feb 28th, 11, 8:05 PM Thread Starter
Don
I see them with two cases too, aluminum and iron, is one stronger? will a Super T-10 live behind my street 489? is it as strong as an M22 like I saw somone claim?
Meatball is offline
post #2 of 26 (permalink) Old Feb 28th, 11, 10:00 PM
Michael
Send a message via AIM to MEJ1990TM
Re: How strong is a super T-10?
From what I understand an iron case (stronger) with the 9310 gears are comparable to an M22. But a run of the mill OEM Super T-10 with an aluminum case will not take the abuse an M22 would all things being equal. Sure you take a brand new Super T and compare it to an M22 that's been abused for thirty years the Super T might last longer. But if you take two brand new transmissions the Super T will not hang with the M22 for very long behind a big block with a lot of torque and sticky tires.
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
MEJ1990TM is offline
post #3 of 26 (permalink) Old Mar 1st, 11, 4:46 PM
I would have to disagree with you about the M-22 being stronger. I think if your gonna run street tires and NO slicks you'll be fine with either one. What rear gear are you gonna run?
1970 Chevelle Malibu
468ci 10to1
Straub solid roller
4 speed
12 bolt 4.11's
60'= 1.561
1/8= 6.97 at 100.14mph
1/4= 10.97 at 123.52mph
whitey70ss is offline
post #4 of 26 (permalink) Old Mar 1st, 11, 4:58 PM
Also get the iron mid-plate, it's stronger
70GS455 is offline
post #5 of 26 (permalink) Old Mar 1st, 11, 5:52 PM
Michael
If that is the case then why didn't they put the 1st design Super T behind the LS5/LS6 Chevelles, L88 Vettes, and cars of that nature? Why was it the Super T-10's weren't put into GM cars until the power levels had dropped off so severely? I like Super T's, they are good transmissions. I ran a couple in my '71 for a while. But to say a Super T is stronger than a Muncie is laughable at best. I'm sorry, but when you are dealing with OEM stuff it just isn't so. I've heard of/seen several Super T's absolutely blow apart when they were being beat on. I've yet to see a Muncie do that. Sure they break, but I've yet to see one scatter it's guts like I've seen Super T's do.
post #6 of 26 (permalink) Old Mar 1st, 11, 8:51 PM
An iron case/9310 ST-10 has a major performance advantage over the M-22:
Available wide-ratio gearsets w/decent first gear ratios!
Euell Florett is offline
post #7 of 26 (permalink) Old Mar 1st, 11, 9:11 PM
mr 4 speed is offline
post #8 of 26 (permalink) Old Mar 1st, 11, 10:14 PM
Michael
Originally Posted by mr 4 speed View Post
You know what is stronger than an M22? A833 !!
Nice first gear ratios too
So is a Toploader. That's why I want to eventually put a Toploader in my Chevelle. But weren't talking about Mopar and Ford transmissions here.
post #9 of 26 (permalink) Old Mar 1st, 11, 10:17 PM
Michael
That may be true, but the severity of the close ratio Muncies 2.20 first gear is really over blown. Unless you are a drag racer a healthy big block with 3.31's out back will work just fine on the street with a 2.20. Anything above that is just icing on the cake.
post #10 of 26 (permalink) Old Mar 2nd, 11, 9:25 AM
I would think that the iron case super t-10 would be an improvement over the non here is specs on the super t-10 http://www.richmondgear.com/07pdfs/RG25.pdf
PART NO. DESCRIPTION 1ST 2ND 3RD 4TH REV. TORQUE
1304000070 2.43 “S” Ratio 2.43 1.61 1.23 1.00 2.35 375 Ft. Lbs.
1304000069 2.64 “W” Ratio 2.64 1.75 1.34 1.00 2.55 325 Ft. Lbs.
7021090 2.64 “X” Ratio 2.64 1.60 1.23 1.00 2.55 325 Ft. Lbs.
1304000072 2.88 “CC” Ratio 2.88 1.91 1.33 1.00 2.78 300 Ft. Lbs.
Notice the tq ratings?
As for diff gear options Auto gear does make an m22w that have gear set ratio that is similar to the m20
http://www.5speeds.com/racing/m22ratios.html
Auto Gear M22 Derivatives for Muncie Transmissions
Designator
1st Gear
2nd Gear
3rd Gear
4th Gear
M22
2.199
1.640
1.274
1.000
M22W
2.559
1.752
1.366
1.000
M22X
2.199
1.506
1.174
1.000
M22Y
2.199
1.506
1.000
0.859
and also they have a new release of an m22z
http://www.autogear.net/whatsnew.php
AUTO GEAR COMPANY, INC. of Syracuse, New York is pleased to announce their latest alternative gearset for General Motor's iconic Muncie four-speed. The 'M22Z' (ratios 2.984/2.043/1.468/1.000) was designed to provide 'cruisers' an alternative to expensive overdrives. According to the company's Chief Engineer, George Sollish, "Now Muncie drivers can have the highway rpms of a fast axle without changing their gearbox. In addition, when paired with a 3.08 axle the M22Z gearset provides the same 1/2 punch of our successful M22W/3.54 combo, so there's no embarassment leaving a light, either. And like all our gearsets, the M22Z can be used in original equipment cases. We're also looking at older Jeeps -- they've used Muncies for years but have never had the 2.98 low we offer before now."
I would sure like to know more about the top loader conversion and the A833 converion
Steven
1st project 67 chev sedan, long gone.
2nd project 64 malibu SS 327 4spd major regret in selling for next project
3rd 56 chevy, my to be drag car sold for current.
Current 65 impala ss, bbc 427 with auto gear m22 4spd
65 Imp SS is offline
post #11 of 26 (permalink) Old Mar 2nd, 11, 10:53 AM Thread Starter
Don
Great discussion guys! I have to ask though, what's an A833?
Meatball is offline
post #12 of 26 (permalink) Old Mar 2nd, 11, 11:56 AM
Randy
A833 is the Mopar 4-speed from the 60s-70s, pretty stout cast iron case transmission.
2012 Camaro SS
03 Suburban 2500 8.1L - Tow Pig
75 MGB - eternal project
03 GSX750F Katana
67 El Camino - Sold
Randy 67EC is online now
post #13 of 26 (permalink) Old Mar 2nd, 11, 12:49 PM
I ran S-T10's for years in my chevelle with a 440, centerforce dual friction, 456 gear, and sticky tires. I broke a few. The weak point for me was where the main shaft and the first gear come together. The needle bearings would mess up resulting in a new input shaft and first gear. These parts are getting hard to find. Just for cruising with treaded street tires one could live a long time.
mrpaticular is offline
post #14 of 26 (permalink) Old Mar 2nd, 11, 4:24 PM
BUT.....which trans SOUNDS cooler?
WHOA!! I though I was driving my car for a second!
TC#3095
dreis454 is offline
post #15 of 26 (permalink) Old Mar 2nd, 11, 7:05 PM
Michael
Originally Posted by dreis454 View Post
BUT.....which trans SOUNDS cooler?YouTube - 68 Chevelle M22 (audio) WHOA!! I though I was driving my car for a second!
The funny thing about M22's is I've driven cars with three different Rock Crushers. They all sound just a little different. But they all three sound equally as sweet.
