Totally confused with this SM 318 3 Speed - Chevelle Tech
post #1 of 5 (permalink) Old May 14th, 10, 1:41 AM Thread Starter
Recently I found out about the small Muncie 318 3 speed. I had one given to me and I am currently running it in my round track super truck. I have been doing all kind of searching for some more of these transmissions because they are super light compared to the Saginaw and all I need is high 1:1 gear.
Here is what I am confused about I have found 3 other transmissions and none of them are like the first one that I found. I have 2 what I believe are the older 318s because they have 16 spline output shafts and the input shafts are different. The trans I have I believe is from a 64 and later but I am not totally sure. The main case casting is 3854726 the tail housing casting is 3856722 and the side cover is 3849584.
The side cover is what I have yet to see one like mine. Mine is the style that has the bolt on post like saginaws, and every 318 that I have found has the clamp on style shifter posts. I would really like to find out what this transmission came in so I can try and find some more like it. I need the 27 spline output shafts so that I can use the same drive shaft with my muncie 4 speed.
ChrisWagnerRacing is offline
post #2 of 5 (permalink) Old May 14th, 10, 8:46 AM
Vince
Re: Totally confused with this SM 318 3 Speed
does your transmission have a mounting area for a cross-member??
i ask because the trans looks very similar to what i recall seeing in 50's chev pick-ups,
i could be wrong.......
VinceS427bb is offline
post #3 of 5 (permalink) Old May 14th, 10, 10:16 AM Thread Starter
Yes I have 2 with the rear mounts and one without. The one without and one of the ones with it has this style input shaft which from what I have found is the older style from like 56s and 57s. They also have these style shifters. The trans that I am trying to find out what it is has a smooth imput shaft without the cut out in it like the one in this picture.
ID:	30617   Click image for larger version
post #4 of 5 (permalink) Old May 22nd, 10, 12:35 AM Thread Starter
Anyone know any more information about these transmissions?
post #5 of 5 (permalink) Old Dec 30th, 12, 4:03 PM
PHIL
Chris, i have one of these trans you are looking for. It has the input shaft without the cut in it, and the bolt on side linkage mounts. I actually removed it from a 64 malibu wagon, and have the same side cover # you stated.....3849584.
My main body casting is the same one used in early corvette....3824197.
And the tail 3 appears to be.....3793670 which i cannot get any info on, it has the trans mount built in.
Phil @ pnw bowtie parts
P N W BOWTIE PARTS is offline
This Thread is more than 1642 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
