driveshaft legnth - Chevelle Tech
post #1 of 8 (permalink) Old Jan 21st, 10, 5:23 PM Thread Starter
Darian
driveshaft legnth
Will a driveshaft from a th350 work with a th400?
cigartoyz is offline
post #2 of 8 (permalink) Old Jan 21st, 10, 5:43 PM
john
Re: driveshaft legnth
no
70 chevelle 468 2 bolt mains,steel crank,srp 14cc
pistons .049 heads 2.19/1.88 manley/116cc,harland sharp roller rockers,Cam 501/527,214/224 at .050.air gap 750 double pump .3.73 posi.9.6:1 compression Th400-Hughes 3,000 stall speed bm holeshot converter. Best time 12.2
job68327 is offline
post #3 of 8 (permalink) Old Jan 21st, 10, 11:06 PM
Ryan
The th350 has a longer tailshaft something like 4" I think. Someone will correct me with the proper size difference. But the th400 is definatly shorter
70 El Camino 383 stroker, Eddy thunder 800, RPM air gap, IK 200s, Chris S. roller cam, MSD 6al2, MSD pro billet dist, coan 3000stall, built th350, 12 bolt 4.10s locker.
Frankenstein idle
http://youtu.be/nzWu0K__zeU
Many pics here
http://s959.photobucket.com/albums/a...aminodragster/
elcaminodragster is offline
post #4 of 8 (permalink) Old Jan 21st, 10, 11:09 PM
The tailshaft length is different, yes. But a t-400 is longer overall. So if you are asking can you shorten a t-350 driveshaft to work with a t-400 yes.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.034 at 148.10, 1.242 60'
bracketchev1221 is offline
post #5 of 8 (permalink) Old Jan 21st, 10, 11:53 PM
john
I suppose the you mean the actual tube itself?I believe the yoke that slips on tailshaft is different and the 400 uses the larger u-joint anyway?
job68327 is offline
post #6 of 8 (permalink) Old Jan 23rd, 10, 12:57 AM Thread Starter
Darian
Yeah...I wanted to shorten my 350 driveshaft for the th400 I got. So this will work?
post #7 of 8 (permalink) Old Jan 23rd, 10, 1:04 AM
Jay
Just need to shorten your shaft and change the yoke for one that fits a T-400.
Elcoman is offline
post #8 of 8 (permalink) Old Jan 23rd, 10, 10:43 AM
Roland
Send a message via AIM to forever young
Hey, does anyone know the legnth for a stock setup for my BB, Muncie and rear for my 70SS? I will add about 1" of height to the front end coil springs for the back in the dat look.
"some people spend their entire life trying to make a difference, US MARINES don't have that problem". Ronald Reagan Semper Fi
forever young is offline
